Author Topic: 12' axial flux project  (Read 1768 times)
dynaman
« on: October 05, 2007, 04:15:54 PM »
this is a shot of the 70' cable TV tower that I bought for 150.00
The crane to take it down was another 250.00  cheep tower
Mount for the Alternator and rotor
Shot of the bracket I made to make the tower a tilt up
This is the bracet installed on the tower
Testing the winding for output
Shot of the rectifier setup
power panel
Another shot showing the battery bank
The wind farm up and running Lots of changes yet to com will keep you posted
« Last Edit: October 05, 2007, 04:15:54 PM by (unknown) »
asheets
Re: 12' axial flux project
« Reply #1 on: October 05, 2007, 02:03:02 PM »
If you were anywhere near me, you would have recouped your losses by selling me those yagi antennas off the tower.  Oh, well.
« Last Edit: October 05, 2007, 02:03:02 PM by asheets »
« Reply #2 on: October 05, 2007, 02:50:52 PM »
nice setup up..
whats the specs on the alt..
and you even got a plane[chopper] ride out of it...
« Last Edit: October 05, 2007, 02:50:52 PM by hiker »
harrie
« Reply #3 on: October 05, 2007, 04:20:02 PM »
Very very nice, retirement is fun huh. I will also bet you will be building a bigger one , I think your hooked. ha. Keep us posted.
« Last Edit: October 05, 2007, 04:20:02 PM by harrie »
jmk
« Reply #4 on: October 06, 2007, 11:38:29 AM »
 Sweet! I like the open land for clean air. I too bet you build a bigger one soon. You should get some nice power at that height. Is the water pumper working too? What area are you located?
« Last Edit: October 06, 2007, 11:38:29 AM by jmk »
dynaman
« Reply #5 on: October 06, 2007, 06:25:19 PM »
The alt. is based on Hugh Piggot's 12' axial flux. It is a 16/12 with the coils wound with 74 turns of #16 wire 2 in hand. I my calculations are correct the unit is averaging 290 watts output
« Last Edit: October 06, 2007, 06:25:19 PM by dynaman »
dynaman
« Reply #6 on: October 06, 2007, 06:30:25 PM »
We are located 20 miles north of Maryville MO. in the northwest corner of the state. The windmill over the well could work if I would ever fix the pump...too many other projects
« Last Edit: October 06, 2007, 06:30:25 PM by dynaman »
« Reply #7 on: October 08, 2007, 04:21:46 PM »
Mounting that tilt-up hinge so high off the base puts one hell of a side-force on the base segment during tilt-up/tilt-down.
I'd mount it right at the base, with the lower part of the hinge embedded in the concrete or bolted to it, or else add an extra guy from the base of the hinge to the anchor in the direction of the winch.
« Last Edit: October 08, 2007, 04:21:46 PM by Ungrounded Lightning Rod »
healerenergy
« Reply #8 on: October 08, 2007, 07:20:58 PM »
How far east of St. Joe. Missouri are you we are 20 minutes south in Atchison Kansas and there are other people here in Kansas and Missouri.
George
« Last Edit: October 08, 2007, 07:20:58 PM by healerenergy »
