Author Topic: one coil alt.......  (Read 1940 times)
one coil alt.......
« on: October 10, 2007, 08:35:24 AM »
still have to space the mags and glue down....
hoping to at least power up some 110 ac cfls...
any ideas on what it might do????????
going to test it on my pedgen...
« Last Edit: October 10, 2007, 08:35:24 AM by (unknown) »
Re: one coil alt.......
« Reply #1 on: October 10, 2007, 03:13:16 AM »
Should make lots of eddy current loss as heat in the solid poles. probably get a bit of ac as a by product in the coil.
« Last Edit: October 10, 2007, 03:13:16 AM by Flux »
« Reply #2 on: October 10, 2007, 02:26:05 PM »
Will also heat the shaft.  Probably not enough to weaken it - but the bearing seals and lube won't like it.
« Last Edit: October 10, 2007, 02:26:05 PM by Ungrounded Lightning Rod »
A6D9
« Reply #3 on: October 10, 2007, 06:31:27 PM »
maybe I'm blind, but I don;t see any coil?
i see a shaft with a funky finger thingy, and then the casing with all kinds of mags on it.
I'm new to this..please tell me more about it?
« Last Edit: October 10, 2007, 06:31:27 PM by A6D9 »
stephent
« Reply #4 on: October 10, 2007, 09:12:24 PM »
Just a swaseg--but
Output = disappointment....aka low/dismal/weak
But if used on a ped-gen---it will make a fair braking/slowdown system.
Or a fair heater if pedaled long enough.
Changing magnetic orientation (as seen by the coil)  in that configuration is gonna be problematic.
« Last Edit: October 10, 2007, 09:12:24 PM by stephent »
« Reply #5 on: October 11, 2007, 07:46:17 AM »
It is made like a car alternator
and it's like the minigen explained clearly here
http://www.windstuffnow.com/main/minigen.htm
« Last Edit: October 11, 2007, 07:46:17 AM by wooferhound »
