Author Topic: 1.5hp pmdc motor as generator  (Read 1595 times)
Kilted
« on: October 22, 2007, 04:15:14 AM »
Currently on offer at ebay.  It has been there for about a month.  I'm sure it will sell some day.  There were two lathe motors larger than this that sold recently.
I'm really curious how good of a generator this motor would make.  To get real power output, would it need to be geared up?
Catalog Number: T56S2014A
Horsepower: 1.50
Armature Voltage: 180 Volt DC
Fields: Permanent Magnet DC
Hertz: 60  (I'm sure this is a typo, unless there is a speed control box.)
Phase: DC
Full Load Amps: 7.0
RPM: 1750
Frame Size: LF56HCZ
Rating: 40C AMB-CONT
Insulation Class: F
Enclosure: TEFC
Base: C Face with Rigid Base
Mounting: F12 Top Mount Box
Shaft Dimension: 7/8 Dia X 2 Long with Keyway
http://cgi.ebay.com/Reliance-PMDC-Motor-1-5-HP-1800-RPM-180V-DC-TEFC-1-1-2_W0QQitemZ270167919953QQih
Z017QQcategoryZ26226QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
--  Brandy
« Last Edit: October 22, 2007, 04:15:14 AM by (unknown) »
Re: 1.5hp pmdc motor as generator
« Reply #1 on: October 22, 2007, 08:11:29 AM »
It would not need geared up.  It'll start 12V charging at about 135RPM.
Looks like a nice motor.  Seems more than a bit steep at $500 for 'as-is No Returns' on eBay?  I expect it'll be there for a while unless someone needs that exact motor.
« Last Edit: October 22, 2007, 08:11:29 AM by ghurd »
kurt
    • website
« Reply #2 on: October 22, 2007, 02:22:08 PM »
it would be good for a 24v system with about an 8' prop or so as long as the shaft size is large enuff you would have to look up a frame chart to be shure of that before buying....... but personaly i would not pay $500 for it you can get a simular one much cheeper if you keep looking.
« Last Edit: October 22, 2007, 02:22:08 PM by kurt »
kurt
    • website
« Reply #3 on: October 22, 2007, 02:25:10 PM »
« Last Edit: October 22, 2007, 02:25:10 PM by kurt »
Kilted
« Reply #4 on: October 23, 2007, 12:43:16 AM »
Thanks for the comments.  I was just wondering how well this would work.  No intention of purchasing, a bit pricey and no place to fly it.
Ok so it would start making power into 12v at low rpm.  How many amps could you actually draw it is only a 7.0 armature?
It would seem to me a better match would a gear up of 3:1 to get the voltage in the range of a SMA Windyboy and use it for direct grid tie?  Then you stand a chance of using the full 1.5hp rating.
--  Brandy
« Last Edit: October 23, 2007, 12:43:16 AM by Kilted »
bsafe
« Reply #5 on: October 25, 2007, 08:07:34 PM »
How does one determine a workable blade  dia for this size motor for 12v and 140v charging? How would the windyboy work with this motor?
« Last Edit: October 25, 2007, 08:07:34 PM by bsafe »
