Author Topic: Large DC pancake motor  (Read 5585 times)
fungus
« on: November 10, 2007, 01:44:16 PM »
Got this motor off ebay for £40; its a 1,120w motor at 3000rpm, 100v;
Taking off the nameplate I find its a pancake motor; theres the magnetising wires wrapped around the magnets and a black disc in the middle- no visible windings?
On the back theres a tachometer- mini 4 pole DC generator- 10v/1000rpm. I chucked a bolt into my cordless drill (the middle of the shaft is threaded) and spun it up; checking the tachometer it was spinning at 5.17v / 517rpm and I was getting 15.57v out, indicates theres about 10% slip on the motor; looks pretty high cutin but could be mounted easily with pulleys?
« Last Edit: November 10, 2007, 01:44:16 PM by (unknown) »
Re: Large DC pancake motor
« Reply #1 on: November 10, 2007, 08:30:42 AM »
Hey Fungus
 Thats a cool motor.The first thing i would do is take it apart and see what makes it tick.
 Thats just me though.
« Last Edit: November 10, 2007, 08:30:42 AM by vawtman »
« Reply #2 on: November 10, 2007, 08:48:18 AM »
I wouldn't unless you have the magic capacitor discharge unit to remagnetise it with those coils. Servo motors are best not taken to pieces if at all possible.
« Last Edit: November 10, 2007, 08:48:18 AM by Flux »
« Reply #3 on: November 10, 2007, 08:56:01 AM »
Learn somethin new everyday.Thanks Flux
« Last Edit: November 10, 2007, 08:56:01 AM by vawtman »
fungus
« Reply #4 on: November 10, 2007, 09:28:44 AM »
I know what makes it tick- its a pancake motor like at http://www.phys.unsw.edu.au/hsc/hsc/electric_motors5.html
except that the armature is cast in resin...
« Last Edit: November 10, 2007, 09:28:44 AM by fungus »
JW
  • Development Manager
« Reply #5 on: November 11, 2007, 10:21:19 AM »
Neat link fungus,
  "Don't worry about the two black wires for the moment."
"Try not to think about the black wire for a moment."
"Let's bring the wire outside the motor,
 and once everything is assembled we zap a gazillion amps through the wire. Think about what direction the magnetic field created by the current through that wire will be in. Perfect! Admittedly it's not a very thick wire to be coping with such a large current (typically several thousand amps), but it's only for a few milliseconds and the wire doesn't have time to complain."
So since the motor doesnt have a nameplate hp, its a servo?
The last time I took-apart a MOSFET, I found three of them in there. needless to say, it never worked again.
Its uttery amazing how much neat stuff is lost and saved by scrap-yards. Its a good feeling to walk thru one, and understand what most of the stuff there is.
JW
« Last Edit: November 11, 2007, 10:21:19 AM by JW »
