Author Topic: Anemometer and Data Logger  (Read 4993 times)
Boondocker
« on: November 18, 2007, 06:08:20 PM »
My turbine is located in a remote location and on my Dad's property on Beaver Island Michigan.  To be able to collect data and monitor the performance of the turbine and wind conditions from afar I installed an anemometer and datalogger.
I admire the skill and electronic knowledge posted on this web site, especially ELT's endeavors.   The method I pursued uses mostly "off the self components".   I found a unit from ARPS that meet the requirements nicely.  http://www.aprsworld.com/wind2/
I purchased the kit versions and fabricated the tower mounting arm and bracket out SS and aluminum myself
The logger has the capability of having three anemometer and three analog inputs.   I used the 2nd  anemometer input to measure the wind turbine rpm.   This was accomplished by "sniffing" the alternator AC frequency.   A pulse is created by using diodes and protecting the circuit using an opto-coupler.  The circuit is shown on BackshedShed DIY Windmills. http://www.thebackshed.com/windmill/PicLog.asp
The logger configures each anemometer separately using a pulse and the basic y= mx + b formula to calculated a wind speed.  So calculating the rpm from the pulse count out of a 12 pole alternator is easily done.
I also wanted to monitor amperage and dcv before boost and cut-in.  For this I utilized the 0-5 dcv analog inputs.  Current is measured using an Allegro Hall Sensor ACS752SCA-050.    Before cut-in voltage is measured through a voltage divider and then passed through an op-amp for buffering and provide high voltage protection.
I placed the components on a proto broad and integrated the outputs to the logger's inputs as shown below.   Then I calibrated and doubled check the inputs verifying they all worked properly before installing the equipment on site.
It works!   Data is set-up to be recorded in 10 second interval (8640 reads/day) on a SD card which I transfer into an Excel Spread sheet.    All the information of interest is there:  time, wind speed, direction, Gust (10sec interval),  Rpm , Max Rpm (10 sec interval),  amperage,  alternator dcv, system (battery) voltage.
It appears the display screen shows instantaneous values, it is very responsive to wind and rpm changes.   What gets recorded is the reading at the end of a 10 second interval.   So if winds are increasing or decreasing at the moment of the 10 second interval, it creates as spread range of the watts produced at that particular wind speed.   Given a large sampling population of values, some meaningful performance values should be able to be inferred.
I'll post some data later on.  Still working on the spreadsheet and making graphs.
« Last Edit: November 18, 2007, 06:08:20 PM by (unknown) »
jmk
Re: Anemometer and Data Logger
« Reply #1 on: November 18, 2007, 03:21:49 PM »
 I like your set up. It makes it a more interesting hobby. I have my tower tilted down now to ad the bicycle speedometer for rpm. It would be nice to add the weather too.  Maybe I will ad a wind direction device for now. I can't afford the rest right now.
« Last Edit: November 18, 2007, 03:21:49 PM by jmk »
jmk
« Reply #2 on: November 18, 2007, 05:15:45 PM »
 On an island in the middle of Lake Michigan I bet you will bring power in all the time. What size turbine do you have, and how tall is the tower? Your guy lines look like they are pretty steep. They will be taking a lot of force. Your tower looks like an ARE tower. My neighbor has one down the road from me. His guy lines are on about the same angle. He has an 11 1/2 foot ARE turbine on top of a 70' tower. They have to adjust the guy wires every now and then. I seen it look like it was going to fall over on a windy day. The cables got sloppy and the tower was rocking. Does your dad live there year round, or is it a vacation spot? It's got to be hard to get back and forth in the winter to main land. I've seen that ice pile up. It looks scary out there! Cold and windy, at least you have some trees. I bet it's a fun place to live and a great get away! Enjoy, and I can't wait to hear your data!
« Last Edit: November 18, 2007, 05:15:45 PM by jmk »
Boondocker
« Reply #3 on: November 18, 2007, 06:45:29 PM »
The blades are 2.8 meters, 9 feet in diameter.   The tower is 84' tall and is similar to the ARE design.  I have not noticed any tower sway in high winds or during gust.   The tower is very solid.  However, if I was to do it again, I'd place the anchors out farther.
I did once momentarily get freaked by the optical illusion of watching the turbine with low clouds passing by.
According to the wind charts it is one the better places in Michigan for wind that is on land.
My Dad has been a full time resident for over 25 years.   You can get to the Island by ferry boat or plane.  Although, the ferry stops running for the winter mid December
« Last Edit: November 18, 2007, 06:45:29 PM by Boondocker »
jmk
« Reply #4 on: November 19, 2007, 04:50:59 PM »
 I know what you mean by the clouds. I opperate a crain at work and if you watch the clouds it looks like the crain is tipping over. It freaked me out the first time.
« Last Edit: November 19, 2007, 04:50:59 PM by jmk »
americanreman
« Reply #5 on: November 20, 2007, 06:38:05 PM »
Just wanted to say hey...I used to spend alot of time on the island, my ex-girlfriends family (sister moved there in the 70's, her husband has alot to do with getting lumber and building supplies to the island from the mainlands..thats how he makes his living,  her parents retired there and built a place).
Her sister and husband own the horse rental facility on the island too, or did anyway at that time...
Small world..keep up the good work!
« Last Edit: November 20, 2007, 06:38:05 PM by americanreman »
