Flux, I've noticed you saying this several times before. This time I can't resist asking - what do you exactly mean:
"use long enough magnets to achieve the flux you need with an average air gap to the stator of at least 1mm."
Do you mean 'long' as in what I would call 'thick', i.e. magnets being 'long' in a radial direction of the rotor ? Your remark would make sense to me if interpreted like that.
Or do you mean long as I would normally call it, i.e. long in longitudinal direction ? ('long' in the direction of the shaft)
Also, I've never imagined that the aluminium sleeve had any other function than providing a non-magnetic case for the magnets, so as not to short flux yet provide a way of safely mounting the magnets and positioning them. I find another (maybe the most important) benefit is that an aluminium sleeve (that's higher than the top of the magnets) protects the delicate nickel coating of the magnets during insertion and removal of the rotor from the stator. Though if that's the only purpose then the method the original poster used in his previous generator would be even better: casting the rotor in epoxy. There will be no eddy currents induced in the epoxy...
To the thread starter: I think the extra weight of using an all-solid steel rotor is hardly an issue. Even in my latest project (a 10 hp, weighing 65 kg originally; the rotor itself weighing ~15 kg, from memory) the few extra kg of an all-steel rotor would be hardly noticeable. It would be even less of an issue in smaller conversions, whereas the added complexity (machining accurate workpieces for the interference fit) requires quite a bit of extra effort.
In an earlier 3 hp conversion I made the rotor/shaft combination out of a solid piece of steel on request of my machinist friend. It was much simpler/quicker for him to turn down a solid piece of steel and grind the bearing locations than to try to re-use the old shaft. Pictures of the work can be found here:
http://www.anotherpower.com/gallery/3HP-induction-conversion
It's the plan to use the same method (but without aluminium sleeve, and using rectangular magnets) on the 10 hp conversion. The rotor/shaft will again be made out of one piece. Costs a bit more in material but saves much more on machining.
Regards,
Peter.
