Author Topic: Flywheel Power  (Read 1305 times)
Flywheel Power
« on: December 08, 2007, 04:53:26 PM »
First the pics.....
With snow on the swing....I'm not going out there!
So I rigged up this little beauty with the usual
cardboard, masking tape, (duct tape where real
strength is required)hot glue....etc.
Hooked up a little stepper motor (thanks Ghurd!)
That little silver gizmo with the wires taped to
the ...er...flexible coupling, direct drive to
the balanced particle board flywheel thru the
mower blade arbor ( an very excellent bearing
assembly BTW) a spare wheel(donut) will replace
this the particle board in the near future.
   Okay 2nd pic is the output at about 300rpm.
, 20 Ma...at about 120rpm and 7 Ma the 3rd LED
gets dim....and when the meter no longer registers and less than 50 rpm...only the one LED is lit.
Makes for a nice power source for experimenting
with LEDs also...
        Its just Fun all the Way !
« Last Edit: December 08, 2007, 04:53:26 PM by (unknown) »
2dumb2kwit
Re: Flywheel Power
« Reply #1 on: December 08, 2007, 01:22:14 PM »
 Norm,
    you gave me an idea. How about a little waterwheel, under the faucet, so when you turn the water on, it powers up an led. Then you can see to wash your hands!
 All joking aside, I enjoy reading about, and seeing the pictures of your "little" projects as much as I do a 17' wind-gen. It appears that you have more fun, than most people, and I admire that. Keep up the good work.
« Last Edit: December 08, 2007, 01:22:14 PM by 2dumb2kwit »
Re: Flywheel Power
« Reply #2 on: December 08, 2007, 02:41:03 PM »
I don't use that much water to wash my hands...
now flushing the toilet....Hmmmm !
If I waited till I built even a 3' wind-gen to
write about it would be quite awhile ....my big
windmills end up never getting hooked up to a gen.
« Last Edit: December 08, 2007, 02:41:03 PM by Norm »
jmk
Re: Flywheel Power
« Reply #3 on: December 08, 2007, 04:25:59 PM »
They already make them. I bought one last year in cool blue. It actually makes the water stream turn blue. The down fall is it is a two inch long unit and gets in the way. I didn't like it.
« Last Edit: December 08, 2007, 04:25:59 PM by jmk »
Re: Flywheel Power
« Reply #4 on: December 08, 2007, 08:54:45 PM »
It's amazing what you can think up to do with old mower parts.
How is the stepper wired?  4 diodes?
The smaller the do-hicky, the bigger the fun!
« Last Edit: December 08, 2007, 08:54:45 PM by ghurd »
Re: Flywheel Power
« Reply #5 on: December 09, 2007, 06:26:46 AM »
The stepper is wired 4 diodes I just plug em in
one at a time with a needle nose pliers nice
tight fit twist the other ends together with a
lead wire and a wure nut....cut the red wire
right before it goes to the socket run it to another
terminal and that's all there is to
hooking it up.
Yep ....the smaller the do-hickey the bigger the
fun...cause you can do it in your kitchen between
meals and with coffee.
   (Ok....clear that stuff off the table we're
about ready for dinner now) (the boss speaking !)
   LOL !
 (51 years yesterday and almost forgot Whew !)
Just as wonderful as the day I met her !
with more smiles than tears !
« Last Edit: December 09, 2007, 06:26:46 AM by Norm »
Re: Flywheel Power
« Reply #6 on: December 09, 2007, 07:47:05 AM »
Yes indeed flywheels make capacitor equvilent storage . Would work with that swing.
« Last Edit: December 09, 2007, 07:47:05 AM by tecker »
zap
  • There's an app for that
Re: Flywheel Power
« Reply #7 on: December 10, 2007, 08:45:07 AM »
"(51 years yesterday and almost forgot Whew !)"
Congrats Norm... that's pretty impressive and I'm glad you remembered.  I hope you and the boss had a nice celebration.
« Last Edit: December 10, 2007, 08:45:07 AM by zap »
Re: Flywheel Power
« Reply #8 on: December 10, 2007, 09:44:59 AM »
Thanks Zap....Yeah we did....kids were here
thoughouly enjoyable day for all !
« Last Edit: December 10, 2007, 09:44:59 AM by Norm »
Re: Flywheel Power
« Reply #9 on: December 10, 2007, 05:12:47 PM »
Your a good man, Norm :)
 Happy Holidays
« Last Edit: December 10, 2007, 05:12:47 PM by vawtman »
