Author Topic: VAWT cutin+coils  (Read 1181 times)
fungus
VAWT cutin+coils
« on: February 07, 2008, 07:54:46 PM »
I started this here (http://www.fieldlines.com/story/2008/2/5/21752/02729),
Got all the wire stripped out now and the connections noted.
The wire I measured at 0.57mm dia - or 23 guage I think , the original ametek motor cuts in at 330rpm with 40 turns of wire.
I'm planning to put this on a Lenz2 rotor, probably 2*3 or 3*4, will have to see, just wondering what would be a good cutin speed to plan for?
Also, I'm a bit worried that the wire needed would be a bit too small, would probably have to be near 0.2mm dia ...
Any ideas?
« Last Edit: February 07, 2008, 07:54:46 PM by (unknown) »
Re: VAWT cutin+coils
« Reply #1 on: February 07, 2008, 01:52:18 PM »
  The cut in speed will be determined by the diameter of the machine.  You can find the rpm's that it will run using the following formula...
Windspeed x 88 / ( diameter x 3.14 ) x TSR = rpm
Windspeed in mph
diameter in feet
Tsr unloaded would be 1.6
Tsr loaded for peak performance would be 0.8
The "88" simply converts mph to feet per min.
On a 3ft diameter machine your looking at a cut in speed of 56 rpm in a 6 mph wind.
« Last Edit: February 07, 2008, 01:52:18 PM by windstuffnow »
