I built the circuit in my
http://www.fieldlines.com/story/2008/2/26/72614/0725">last diary, and I'm still waiting for a decent wind to test things out. Isn't that always the case? 20 to 30 + winds when you're getting things ready, and then it's like you're in the eye of a hurricane.
At first I didn't think that having separate grounds for battery and generator would be a problem. I was thinking of using batteries as the power source for MOSFETs but now I realize that I can't (at least with my limited understanding of electrickery). MOSFET ground should go to generator ground, and if a use the battery as a source, then MOSFET ground also has to go to battery ground. Oops. So, I'm looking at putting the MOSFET on the battery + terminal.
From looking at different chips to drive MOSFETs in a buck converter, I've noticed that almost all use a capacitor which I think is used as MOSFET return. I'm not explaining this very well, and a picture is worth a 1000 words:
C1 is the cap is talking about. The SwCADIII simulation(here) seems to show that it could work. Anyone try something like this?
Big
