Author Topic: Bought Cable for Power Lines , etc.  (Read 1717 times)
« on: April 15, 2008, 11:11:29 PM »
I went to my favorite surplus store today intending to buy a winch for my ATV to help with moving heavy stuff like logs, hoisting towers, etc.
I came away with 250 feet of #00 overhead feeder cable in Aluminum. 2 coated conductors and one bare hanger cable. $135 for the cable.  I did not come home with the winch. Such is the nature of surplus and salvage stores, I guess.
This roll will reach from my turbines all the way to the batteries with plenty for neat install.
I took some photos. They are high resolution so I just put a link to them.
http://www.anotherpower.com/gallery/album50/100_1225
http://www.anotherpower.com/gallery/album50/100_1226
http://www.anotherpower.com/gallery/album50/100_1227
I hope 00 is big enough to carry the power from 2 10 footers and a 6.5 footer because thats what I have going in up there.
I picked up some connection grease for the Al cable and a couple terminal blocks for the transition to my copper cable on either end. I also grabbed 5 GE Tranquell brand 650 volt, 3 pole  Secondary arrestors. Link to pictures:
http://www.anotherpower.com/gallery/album50/100_1229
Seemed like cheap lightning protection at $6 a pop.
Just had to share the good score.
« Last Edit: April 15, 2008, 11:11:29 PM by (unknown) »
electronbaby
    • Windsine.org
Re: Bought Cable for Power Lines From Turbines, et
« Reply #1 on: April 15, 2008, 06:00:15 PM »
very nice  :-) I like those terminal blocks in the pic with the arrestors. Great score :-)
I think you'll be allright on that distance run.
 Your gonna keep the rectifiers at the tower base i guess...or maybe on the turbine.
« Last Edit: April 15, 2008, 06:00:15 PM by electronbaby »
Have Fun!!!  RoyR KB2UHF
« Reply #2 on: April 15, 2008, 07:11:23 PM »
Roy;
I had a pile of copper #6 - 4 cable in 50 or so foot lengths all picked out probably 200# and happened to ask if they had anything heavier and longer. He said no but was assuming copper. The other fellow mentioned he had some "#2" rolls in the warehouse. He went and got it and I left the copper there. My measurements say its #00. Half the price per # than copper cable.
Those terminal blocks are steady supply there. I can grab some for you if you might need some. in general they price stuff at 1/3rd of retail new. Its a mix of used and new old stock but always clean. $6 each for those arrestors [new] and $8 per terminal block.
Lots of fun watching things finally pulling together.
Thanks for your comments.
« Last Edit: April 15, 2008, 07:11:23 PM by TomW »
« Reply #3 on: April 15, 2008, 09:24:22 PM »
Hey Tom.
Looks like I better get some gennys back up in the air. None at the store and only 4 at home right now.
Your catching up with me real fast.
« Last Edit: April 15, 2008, 09:24:22 PM by Jerry »
« Reply #4 on: April 16, 2008, 12:15:33 AM »
Well I just bought the heaviest wire ever for me (4x 4mmsq cores) to route solar PV and wind round the outside of the house.  Overall diameter 15mm (ie >0.5"), so edging into the same manliness category as yours if it stands on tiptoe and speaks deep.  £170 for 50m.  Eeek.
« Last Edit: April 16, 2008, 12:15:33 AM by DamonHD »
ZooT
Re: Bought Cable
« Reply #5 on: April 16, 2008, 01:28:34 AM »
Heck.......and I was looking at a 30 foot 10 guage extension cord......now I've suffering from cable envy 8^P
« Last Edit: April 16, 2008, 01:28:34 AM by ZooT »
snowcrow
« Reply #6 on: April 16, 2008, 04:43:44 AM »
  Nice score Tom :>  Thats the kind of cable I need for my 10'er!!
Blessings, Snow Crow
« Last Edit: April 16, 2008, 04:43:44 AM by snowcrow »
Re: Bought Cable for Power Lines , etc.
« Reply #7 on: April 16, 2008, 06:31:13 AM »
That's house drop cable for around 100 amp service about 3 volt drop 250 'at 24 volts .   It's easy enough to get 120 ' in 2" pipe you might want a pull box and lube for 175 ' a pull box for sure with 200 ' .
« Last Edit: April 16, 2008, 06:31:13 AM by tecker »
« Reply #8 on: April 16, 2008, 08:03:59 AM »
tecker;
Thanks for the info. This is pretty stiff with 3 together. I do have conduit to the towers [2"] intended for data cable for monitoring, as well as a buried #6 -3 with ground armored cable I use now with doubled conductors. Losing a fair bit in that I am sure.
I will probably go low tech old school on this cable run. It runs near a dilapidated fence line that I need to upgrade anyway. I will probably set railroad switch ties [14 to 16 ft long] as corner posts and run the cable suspended along the fence. It makes a couple jogs in the route but I have enough cable for it now. It will also be out of reach at 8 feet or so and not in any areas equipment goes under it.
All advice appreciated, way over my head now!
Thanks for the response.
« Last Edit: April 16, 2008, 08:03:59 AM by TomW »
« Reply #9 on: April 16, 2008, 04:31:42 PM »
Spring must be showing it's face out your way good luck on the upgrades.
« Last Edit: April 16, 2008, 04:31:42 PM by tecker »
