Author Topic: Back-up power  (Read 910 times)
bj
Back-up power
« on: May 03, 2008, 11:02:16 AM »
     I am almost afraid to post this after the last diary entry.  But,
it was fun.
     Just finished the back-up gen set.  It is a 12.5 HP Briggs, with
a direct coupled 5000 watt (peak) alt.  It gives me enough to run
everything except the welder.  I don't expect to have to use it often,
but nice to know it's there.  Especially when the power goes out,
and it is -40C.  Come to think about it, I guess I won't be welding
much at -40.
     I did add, for those of you that will think of it, a micro switch
on the main breaker.  Can't start the engine until the main is tripped.
Don't want to kill any linemen.
     Someday, with luck, I won't have a grid hookup, and I can remove
the switch.   Until then, this is just one more step.
        bj
« Last Edit: May 03, 2008, 11:02:16 AM by (unknown) »
bj
Lamont AB Can.
thirteen
Re: Back-up power
« Reply #1 on: May 03, 2008, 07:13:36 AM »
Does it have a cycle meter on the genset? If not I would suggest you barrow one to test and make sure it is close to 60.5 cycles. There has been several gensets recently sold around here that were good buys but they were all at 50 cycles not 60. Most of them are adjustable. Just a suggestion.  Sound like a good safty switch idea you'v used. I've seen three with just indicator lights that tells you there is grid power. And that you need to throw the main breaker. Best of luck getting off the grid. 5 yrs 22 days and off grid off work off to mountains I go.
« Last Edit: May 03, 2008, 07:13:36 AM by thirteen »
MntMnROY 13
bj
Re: Back-up power
« Reply #2 on: May 05, 2008, 05:25:36 PM »
    Thirteen--Have a WattMiser--and I suspect it is a bit off, but
measured grid, and set genset to same.  It reads 59.9 Hertz on grid,
so I set genset to same.  Need to do a bit of fine tuning on the
Governor on the Briggs, as it seems a bit dodgy on load changes.  Have
lots of experience with these, and should not be a problem.
     Glad you are off the Grid--Hopefully I can follow soon.
     In the meantime, Thanks.
     bj
« Last Edit: May 05, 2008, 05:25:36 PM by bj »
bj
Lamont AB Can.
