Author Topic: April  (Read 1312 times)
Capt Slog
April
« on: May 04, 2008, 04:50:02 PM »
Ok, Not very active I know, but I cleaned up a few loose ends, managed to light another couple of rooms and my front door.
The first thing I did was tidy up my board where all the power goes in and out.
It doesn't look very tidy now but there were even more cables around than this before I started.  The additions to the board are the fuse box that you can see at around 7 o'clock and the regulator that sits next to it on the bit of light pine.
I belated realsed that a fuse box was a must, and built one that can hold upto 5 fuses.  Each fuse is connected to the 4mm sockets top and bottom of the box.  I've used 4mm plugs to take the power around and off the board.  I've just begun to wonder if that might not be the safest idea as it's easy to make a wrong conection.  However, it is easy to disconnect anything really quickly, and to put meters in almost anywhere.  At the moment, there are two fuses being used and these are both 1A.
The regulator puts out 12v via a 2940 chip, and I'm running this into the house using the third (usually earth) lead of my three core flex.  This means that I can put in individual lights to this regulated line, but if there are a lot of lights in one locale, they have their own reg and this comes off the other line.  (They share the negative).
I can hear the alarm bells ringing now.  Yes, I do realise that the negative is taking both loads, but the total current is very low, it's all less than 1 amp so far and very unlikely to go above 3.
The reason I'm doing it like this is that I have a few lights that are always on/active.  One of them being above my front door......
This is a standard downlighter fitted with a MR16 LED, and runs through a little light detecting circuit so that it only comes on at dusk.  It gives a lot of light and is very effective.
« Last Edit: May 04, 2008, 04:50:02 PM by (unknown) »
Re: April
« Reply #1 on: May 04, 2008, 11:04:47 AM »
Looks Great!
What is to the left of the bridge rectifier?
« Last Edit: May 04, 2008, 11:04:47 AM by ghurd »
Re: April
« Reply #2 on: May 04, 2008, 12:09:28 PM »
Good job: looks satisfyingly neat and tidy.
I put a bit of by 12V cabling (in the kitchen) into PVC trunking today.  First time I've done it but I think it looks at least as tidy as to stuff near it done during the install of my solar PV system by real certified grown-ups!
PS. I like your porch light and I am tempted to do something similar.
« Last Edit: May 04, 2008, 12:09:28 PM by DamonHD »
Re: April
« Reply #3 on: May 04, 2008, 12:11:22 PM »
What Watts is that porch light?
« Last Edit: May 04, 2008, 12:11:22 PM by DamonHD »
Capt Slog
Re: April
« Reply #4 on: May 06, 2008, 01:57:06 AM »
That's a switch so that I shut off the power from the solar panel, makes it easier to see what's coming out of the windturbine alone should I need to.  The bridge rectifier is wired as a blocking diode for the panel.
« Last Edit: May 06, 2008, 01:57:06 AM by Capt Slog »
Capt Slog
Re: April
« Reply #5 on: May 06, 2008, 02:13:09 AM »
The light is 1 watt, a bit on the blue side but reasonably bright.  The shot is taken with a digital camera which of course tend to do well in the dark, but it's a fairly true image.
The bulbs came from here....
http://www.ebest24.com/en/mr16-20-leds-12v-wide-angle-white-spot-light-bulb-lamp.html
and the downlights are from screwfix....
http://www.screwfix.com/prods/98827/Lighting/Internal-Lighting/Recessed-Lighting/12V-Halogen-Downlig
hts/MR16-Downlights/Low-Voltage-Halogen-MR16-Adjustable-Chrome
the downlight comes with all the fittings and they're easy to put in.
« Last Edit: May 06, 2008, 02:13:09 AM by Capt Slog »
Re: April
« Reply #6 on: May 06, 2008, 04:04:08 AM »
Thanks!
I use a 3W to work by in the evening, but I could leave a 1W running all night if I had to...
« Last Edit: May 06, 2008, 04:04:08 AM by DamonHD »
Re: April
« Reply #7 on: May 06, 2008, 04:08:35 AM »
Next question: what are you using as your "light-detecting circuit" given that it should eat a lot less than 1W to be worth using at all given your efficient set-up!
« Last Edit: May 06, 2008, 04:08:35 AM by DamonHD »
Capt Slog
Re: April
« Reply #8 on: May 06, 2008, 06:55:33 AM »
It's just a simple light dependent resistor circuit that switches with a transistor.  The base of the transistor is adjustable with a potentiometer and that sets the light required to turn it on.  Uses next to sod-all.
Would you like one?  Email me.
« Last Edit: May 06, 2008, 06:55:33 AM by Capt Slog »
Re: April
« Reply #9 on: May 06, 2008, 07:48:41 AM »
Have done so, thx!
« Last Edit: May 06, 2008, 07:48:41 AM by DamonHD »
