I did some TSR and Length measurements based upon what I figure my approximate cut-in should be. But here's the major snag, as far as I can tell. According to Warlock's blade calculator (unable to
check others at the current time), most TSR and Length combinations
result in blades that are impossibly wide at the Root.
Warlock's calc says not to worry, use a more reasonable number based upon your lumber.
But here's what I've discovered.
Plugging in different TSRs, with all other items being equal, as TSR
increases:
- the theoretical Root becomes wider
- the theoretical Root angle becomes shallower
- the Tip becomes wider
- the Tip angle becomes shallower, even going negative in the calculator.
All of the root widths are unreasonable, meaning noneof the numbers are relevent. No matter what the calculated width should be, it'll always REALLY be 5.5 inches.
The resulting effect is that the typical angle of attack (4 degrees)
point of each blade moves closer to the Root as the TSR increases. The
negative angles are worrisome. Surely we don't want the blades to twist so much as to start cutting into the wind. I think that's the problem
with theoretical things like calculator programs.
Since I don't have lumber that is,say, 47.1 inches wide, I have to
limit the root to 5.5 inches for 2x6 wood. That means I don't have much control over the actual TSR of the final blade, except to change the location of the 4-degree point along its length. With a specific piece of lumber, the only factor I really have control over would be the length itself.
So here's my idea. I will build a set of blades with a constant angle
from the tip through approximately 75% of the length. At that point, I
plan to start a twist up to something steeper at the root. That's just to try to get a little extra kick in low winds and have SOME twist.
Blades with a 4-foot radius (an easy number for standard lumber sizes), would have about three feet at a four degree angle. My thought is that if the blades end up being too long (slow), I can easily cut the ends off without changing the angles for each calculated length.
Because of the limitations of the source material, I don't think I'll be able to make a blade-set that accurately conforms to a specific calculated TSR anyway (can anyone?). The only thing I think I can really control is the length (have I mentioned that? (wink)). That is why I decided to try this approach.
Plugging numbers into other calculators (Ed Lenz's and Alton Moore's) may result in totally different numbers, and therefore another theoretical approach.
Another reason for trying the mostly solid angle was for ease of construction.
Right? Wrong? Post a comment and let me know!
(Sorry if the formatting is off. My mobile device is a bear to edit text with.)
