Author Topic: Cheap dump load  (Read 2633 times)
frackers
  • Country: nz
  • Picard spits "Hello"
Cheap dump load
« on: July 21, 2008, 09:01:41 AM »
As promised, a picture of the 'wire wound resistor' made from fence wire.
Its 1m long and 0.5m in diameter and with something like 45m of wire on it - it presents a resistance of 1.88 ohms
I might try it if we get any wind - its really for testing the genny off the tractor PTO
« Last Edit: July 21, 2008, 09:01:41 AM by (unknown) »
Re: Cheap dump load
« Reply #1 on: July 21, 2008, 08:41:06 AM »
Looks like a great idea for a Camp Fire Starter
« Last Edit: July 21, 2008, 08:41:06 AM by wooferhound »
Re: Cheap dump load
« Reply #2 on: July 21, 2008, 08:47:37 AM »
Hey wooferhound;
   I was going to say something of the same :-)
Depending on the heat, I'm thinking those wood stand-offs will do just that.
« Last Edit: July 21, 2008, 08:47:37 AM by Bruce S »
Re: Cheap dump load
« Reply #3 on: July 21, 2008, 09:08:42 AM »
Sounds safe to me, for 12V.  About 7.7A, 110W.
Only ~1W in 16" of wire?
« Last Edit: July 21, 2008, 09:08:42 AM by ghurd »
Re: Cheap dump load
« Reply #4 on: July 21, 2008, 11:50:12 AM »
Interesting. So at say, at 10 amps its 188 watts [not a problem] but at 100 amps it will be creating 18.8KW? Spread out over that length I wonder how hot any one point of contact will get?
Likely quite safe for a lot of testing use before it chars too much. How many of you push 100 amps for long?
Great use of stuff on hand especially in spring during fencing season.
I don't see the gage mentioned?
« Last Edit: July 21, 2008, 11:50:12 AM by TomW »
Re: Cheap dump load
« Reply #5 on: July 21, 2008, 11:56:03 AM »
Could be an alternate way to keep the deer out...  First 300V on the nose.  Then 300C on the nose if they don't wise up...
« Last Edit: July 21, 2008, 11:56:03 AM by DamonHD »
Re: Cheap dump load
« Reply #6 on: July 21, 2008, 12:43:41 PM »
Don't people hang those things over their patios to zap bugs?  Hehe  Looks nice.
« Last Edit: July 21, 2008, 12:43:41 PM by SparWeb »
frackers
  • Country: nz
Re: Cheap dump load
« Reply #7 on: July 21, 2008, 05:54:09 PM »
Seems like it was one and a half hours well spent :-) And all scrap materials - even the nails were reclaimed from a bunch of pallets!
It will be on a 24volt system so I expect that I'll only run it up to about 35volts (i.e. without a battery bank, just the genny on the PTO) where the full length will be dissipating 650watts (35^2 / 1.88).
For higher current tests where I want to load the genny to about 40amps at 28volts (max design charge current on a fully charged bank) the 1120watts will be spread over about a third (0.7 ohms for that load of course) of the wire length so I expect it will cook then - so long as the smoke isn't the magic variety that makes all the electrons go round I think I'll be OK...
« Last Edit: July 21, 2008, 05:54:09 PM by frackers »
