Author Topic: First attempt at carving some wood blades  (Read 829 times)
« on: August 11, 2008, 04:51:32 PM »
The blanks are each 24 inches long 5 inches wide
at the base tapering to 1-3/4 inch at the tip,
they're only 1 inch thick so not much room for
twist. They will be bolted to a 18inch long x 6 inch
3/16 inch steel plate.
I'm wondering if anyone can suggest what angle I
should use for the base angle so it would start
in an 8mph wind?
I plan on having a reduction gear drive a small
piston pump.
Just as a side note I was thinking of painting
the 3ft inner radius yellow and the remainder a
flat black....maybe the neighbors won't notice
it replaced my small existing yellow 3 footer pvc ?
« Last Edit: August 11, 2008, 04:51:32 PM by (unknown) »
FishbonzWV
Re: First attempt at carving some wood blades
« Reply #1 on: August 11, 2008, 06:57:33 PM »
Norm,
One inch does not give you much.
I would try to find at least a 2x6 and even better would be a rough cut 2x6.
I would also go with 5 blades for such a low wind start with gearing. My 5 blade mill will start up way before the 3 blade. If you stay with the one inch you will have to use it all.
Fishbonz
« Last Edit: August 11, 2008, 06:57:33 PM by FishbonzWV »
H.F.Fisher 1925-2007
« Reply #2 on: August 11, 2008, 09:55:23 PM »
Whew...I think I made a mistake on this...to top
it off I used a piece of treated wood that they
use for outside floor decks pretty hard stuff...
all hand tools saw, chisels, and wood plane,
except for the fine finish...a belt sander.
 Took about 3hrs....but maybe I'll make the
matching blade and try for about 250 rpm in 8
mph wind to drive a little stepper motor about
200 Ma..
....gotta start somewhere huh?
 My next one will be a five blade like you
suggest....thanks for the advice.
« Last Edit: August 11, 2008, 09:55:23 PM by Norm »
