Author Topic: Conversion question  (Read 1483 times)
2windy
Conversion question
« on: September 14, 2008, 02:27:15 PM »
I have 2 questions that I can't find answers to while searching the board. I'm just about done turning the rotor down on the lathe, but I don't quite know where to stop. Approx.how much air gap should I leave? I have read, the less the better and also I don't think I left enough gap because I can't turn it. The other question is glue. I am making a cage out of pvc and was wondering the best glue to hold the neos in? Thanks for any help!
« Last Edit: September 14, 2008, 02:27:15 PM by (unknown) »
Re: Conversion question
« Reply #1 on: September 14, 2008, 08:48:13 AM »
Hi 2windy
 Is the cage rubbing?Just get it so it runs freely.
 I used a product called Power Poxy for my 54pl.No need for cageing or potting just a temporary template till the stuff cures.
 Mark
« Last Edit: September 14, 2008, 08:48:13 AM by vawtman »
« Reply #2 on: September 14, 2008, 07:19:36 PM »
Super glue the mags in place and wrap the rotor in filament tape that will hold them to check the alignment and gap and get some scope shots . Acetone can remove the glue , turn it and reset as many times as necessary .
« Last Edit: September 14, 2008, 07:19:36 PM by tecker »
« Reply #3 on: September 14, 2008, 09:53:32 PM »
Are you sure it isn't just a bad case of cogging?
Seems like if it went in OK, it should be able to turn.
I'd try turning it just a bit with a pipe wrench, in a quiet room.  Listen for rubbing.  Turn it all the way around at least once (some small or cheap motors are not very well centered from the factory).
If it fits in with a few layers of filament tape, it shouldn't rub.
Don't use tape that stretches!
How are the magnets stuck to the rotor now?
There is a chance one jumped to the laminations, and the thing is binding.
I use 24 hour cure epoxy.
« Last Edit: September 14, 2008, 09:53:32 PM by ghurd »
« Reply #4 on: September 15, 2008, 10:17:32 AM »
A pvc cage is not a gtood idea as pvc will deform with heat maybe a layer of fiberglass .I haven't had a conversion potting come loose from a rotor  yet . I use urethane epoxy and it just gets harder with a little heat.
« Last Edit: September 15, 2008, 10:17:32 AM by tecker »
DanG
« Reply #5 on: September 15, 2008, 02:38:32 PM »
Bobbyb, I think your comment was deleted due to image size.
A 1536 x 2048px image is NOT allowed - 1520KB in size was instant doom too.
  • If your images are bigger than 640x480, it messes up the page view format for people that have smaller monitors. PLEASE shrink them down to 640x480 or smaller before posting. The File size should be less than 150k to be friendly to our many Dial-Up users. You can use any standard photo editing software to do this.
  • See http://www.fieldlines.com/special/faq for guidelines.
This comment will self-destruct in 24-hours. Thank you!!
« Last Edit: September 15, 2008, 02:38:32 PM by DanG »
« Reply #6 on: September 15, 2008, 05:46:27 PM »
I'd go with the gap from the original rotor.  Let the motor designers worry about mechanical and thermal tolerances and the like.  B-)
« Last Edit: September 15, 2008, 05:46:27 PM by Ungrounded Lightning Rod »
