Author Topic: Wind  (Read 962 times)
bj
Wind
« on: December 03, 2008, 09:06:52 PM »
     It has been 2 and a half years now, and I've learned a few things,
although, more would be better.
     Failures--the tower was a classic.  Light tower, for testing, and
not enough clamps on the guys.  Had more sections, so back up with some
improvements.  Next was a bearing.  It lasted a bit over two years, so
not too bad, and I caught it before anything else was damaged.  Last was
the tail.  A couple of years ago someone warned of the limitations of
aluminum.  They were spot on.  Tail is on the roof.
     Good stuff--ALT behaved itself well, cheap glass blades have survived
90 KPH winds (measured) with no furling.  Scary though.
     Cost-- had the tower (free).  Bought the blades ($120).  Built the ALT so, cost was Magnet ($250) bearings ($4) wire ws free from a sympathetic local rewinder, Small welding cable ($60) and finally four
free D-8D batteries.
     It's been fun, is worthwhile, especially considering cost, now it's time to get serious.
     bj
« Last Edit: December 03, 2008, 09:06:52 PM by (unknown) »
bj
Lamont AB Can.
Re: Wind
« Reply #1 on: December 06, 2008, 03:07:21 AM »
so whats in the works??????     :}
« Last Edit: December 06, 2008, 03:07:21 AM by hiker »
bj
Re: Wind
« Reply #2 on: December 07, 2008, 06:47:44 AM »
     Hiker---One of the things I wanted to know was how much wind power
was available to me-here.  (lamont AB) What I now know after two years
is that there is enought wind to break cog force 5.4 days a week. (8KPH)
     That however is not charging, just turning enough to latch a small
relay.
     Peak winds during that time have exceeded 60KPH twenty seven times.
     Longest duration above 60 has been 22 hours.
     All this tells me is that there is usable power, so I am going bigger.
     I like a lot of the stuff the Dans' have been doing, so I started
with their new book.  (here in four days)  I  have enough space to build
whatever I want, so, probably about a 12 footer to start.
    Solar is fairly well proven, and we get lots of sun, but it is fairly expensive, so I will leave it until last.
    Eventually, I would to get rid of the power pole, but that is a ways
off yet.
    bj
« Last Edit: December 07, 2008, 06:47:44 AM by bj »
bj
Lamont AB Can.
