Author Topic: Inspiration and morale needs a boost  (Read 7909 times)
Re: Inspiration and morale needs a boost
« Reply #33 on: January 11, 2009, 08:23:11 AM »
Well here's my main drain rider now you could say it's a rider mess I was hacking on the buck from 30 to 12 .I just about got it . I included some photos of some delcos that are going out soon  . I strip down the rebuilds and chechum out or rewind higher voltage . A good rewind is 12 to14 turns 18 200c (Dosen't take much wire) that's what's on the bike now . The others are stock 5 turns of 14 .The one on the right has the y node out for Wye delta jerry  .Pwm the rotor in a boost config for a nice pulse to a second battery of like voltage as the charging battery  :kept below 35 volts differential to keep the regulator on the pwm happy .
Lifetime warranty (the diodes come out and the studs come out thru those holes as the piv on the diode is toooolow and pop easy )
 The great part about this as a test rig is you can get a could feel for the power band on the alternator under test . Laughable picture I but a work in progress in winter no less
« Last Edit: January 11, 2009, 08:23:11 AM by tecker »
zap
  • There's an app for that
« Reply #34 on: January 11, 2009, 08:45:45 AM »
Hehe... no, I don't live near you Norm.  If I did I probably would have dropped off a mower by now.
Here's what mine looked like when it first came off the "assembly line" 5 or so years ago.
She's looked like this for about 4 years now and gets used quit a lot.
She's not as portable as she was but the "gearing" is much better and near silent compared to the homemade drive gear she used when first built.  The belt is a "V" made for swamp coolers and was the only thing I had to actually buy.
I'd still like to enclose the motor and maybe add one of Bruce's nicd packs with a cigarette lighter plug or 2.
« Last Edit: January 11, 2009, 08:45:45 AM by zap »
« Reply #35 on: January 11, 2009, 08:50:51 AM »
Yeah cold is deceptive, especially if there isn't
any wind...I can remember one time got in the '78
Pinto stationwagon and the whole thing seemed
pretty 'solid' like sitting on a wooden bench
engine seemed sluggish on starting...and as I
drove thu town the temperature read -22 F.
....and that's the coldest I've ever known....
« Last Edit: January 11, 2009, 08:50:51 AM by Norm »
DanG
« Reply #36 on: January 11, 2009, 11:06:06 AM »
Norm posted a comment with two over sized images. I was told image rules apply to old folks too, so they are gone. This is not about the blurry focus Norm!.. Here is the text from his comment. Maybe he will care to reduce quality on those two 200kb images to about 1/10th that size and repost?
Nice CmeBREW, here is mine in it's present stage of development....
 This what you mean by arm exerciser?....had plenty of this in shoulder therapy 40watts average for half hour 3 times a week for 2 months.
 See that little generator...friction drive on the tire ?
Like I said next modification is bike chain aroung this tire and a 2 inch procket...10:1 ratio or 600 rpm when the crankspeed is 60
 I don't mess with 10 speed bikes for this...just the different seperate sprockets from them, to put on the generator shaft Finally got the batt.pak up to 13.50...(40 cells
average 1.35 each)
 What size/ kind of generator do you use ?
( :>) Norm
<HR>
Photo Size is limited to 150K bytes and/or 640x480. Please re-size your photos before posting them, whether they on our server or yours. If you post large images, it causes problems for other users who have slow internet connections and small screens.
Frequently Asked Questions
« Last Edit: January 11, 2009, 11:06:06 AM by DanG »
« Reply #37 on: January 11, 2009, 02:43:34 PM »
Zap, Thats about the coolest one I've seen so
far...in the exact same setup...which do you think
would work better....an Ametek or treadmill
motor?
remember this one....from a posting I did a few
years back?
I actually charged that little 6v 'powerwheels'
battery by handcranking the lawnmower wheel.
See the knob...the chrome socket screwed into the
side of the rubber tire with a lag screw?
All that's needed is a bigger tire and belt.
Got any data on the performance of your machine?
« Last Edit: January 11, 2009, 02:43:34 PM by Norm »
zap
« Reply #38 on: January 11, 2009, 03:54:15 PM »
I have a treadmill motor sitting around here somewhere but I've never hooked it up to be pedaled and I have zero experience with Ametek.  When I was doing mine I was more interested in "free" than in performance.
I would think some of the cordless tool motors would now be worth investigating since some of their voltages are starting to get up there plus they are usually well built and much smaller than my boat anchor.
I remember most all of the different ways you turned your treadmill motor.  It's nice that there's more info out there now for different ways of doing a pedalgen.  When I was doing mine there wasn't a whole lot of info out there.
I used to have numbers on the performance on mine... I'll have to dig around and see if I can find them.
« Last Edit: January 11, 2009, 03:54:15 PM by zap »
« Reply #39 on: January 13, 2009, 05:35:02 PM »
Maybe it can snow forever?
My truck, today, 45 minutes before sundown, on a well-plowed road.
And I drove it 4 hours ago.  :-(
http://www.otherpower.com/images/scimages/2050/MyTruck.jpg
« Last Edit: January 13, 2009, 05:35:02 PM by ghurd »
pepa
« Reply #40 on: January 14, 2009, 09:59:36 AM »
the last time i saw that truck, it had a hugh buck in the back and a big grin on the owners face. having fun pepa.
« Last Edit: January 14, 2009, 09:59:36 AM by pepa »
thirteen
« Reply #41 on: February 06, 2009, 08:34:36 AM »
IRS thing is ok. But they get stupid ever so often 4 yrs ago the send me two letters asking me if I would come down and get my return after they audited me. They owed me $.98
« Last Edit: February 06, 2009, 08:34:36 AM by thirteen »
MntMnROY 13
