Author Topic: Dexter Hub  (Read 4951 times)
trumpets3u
Dexter Hub
« on: February 11, 2009, 08:34:01 PM »
Where is the best place to pick up the Dexter Hub PN 81-9A for the 10' turbine?
                    Thanks Brian
« Last Edit: February 11, 2009, 08:34:01 PM by (unknown) »
Re: Dexter Hub
« Reply #1 on: February 11, 2009, 04:59:54 PM »
Dexter is a brand name trailer hubs . you can get a 5 bolt and a 1 ' spindle from these guys
  tp://www.surpluscenter.com/sort.asp?UID=2009021117551761&catname=wheels&keyword=TTSH
« Last Edit: February 11, 2009, 04:59:54 PM by tecker »
Re: Dexter Hub
« Reply #2 on: February 11, 2009, 05:25:57 PM »
one thing about the dexter hub is, they machine the backside.
so you can put a rotor on there.
« Last Edit: February 11, 2009, 05:25:57 PM by electrondady1 »
trumpets3u
Re: Dexter Hub
« Reply #3 on: February 12, 2009, 05:12:08 AM »
Thanks I was hoping to find the 4 bolt hub.
                Brian
« Last Edit: February 12, 2009, 05:12:08 AM by trumpets3u »
bj
Re: Dexter Hub
« Reply #4 on: February 12, 2009, 05:55:54 AM »
    Depends on where you live.  I picked mine up at Princess Auto. They
had hubs/spindles as a unit, with the spring loaded grease cup.  These
are for water submersion.  About $60 per assembly.
    I believe they are Canadian only, but I believe they have a mail order
service.
   bj
« Last Edit: February 12, 2009, 05:55:54 AM by bj »
bj
Lamont AB Can.
Re: Dexter Hub
« Reply #5 on: February 12, 2009, 06:18:57 AM »
You can get them at Northern also .
« Last Edit: February 12, 2009, 06:18:57 AM by tecker »
sk windpirate
Re: Dexter Hub
« Reply #6 on: February 12, 2009, 08:45:40 AM »
Hi
Princessauto dot com
Winipeg Manitoba. That is the mailorder office. They will ship from there.
« Last Edit: February 12, 2009, 08:45:40 AM by sk windpirate »
wdyasq
Re: Dexter Hub
« Reply #7 on: February 12, 2009, 08:54:03 AM »
$30
http://www.etrailer.com/pc-TPH~34822BX.htm
took a 30 second Google search.
« Last Edit: February 12, 2009, 08:54:03 AM by wdyasq »
DanB
    • otherpower.com
Re: Dexter Hub
« Reply #8 on: February 12, 2009, 09:34:41 AM »
yes, that's exactly what we use/where we get them.  Thanks Ron.
« Last Edit: February 12, 2009, 09:34:41 AM by DanB »
trumpets3u
Re: Dexter Hub
« Reply #9 on: February 12, 2009, 03:10:20 PM »
Thanks I did look but I see the part no. was not correct in the right up
           Thank a lot Brian
« Last Edit: February 12, 2009, 03:10:20 PM by trumpets3u »
imsmooth
Re: Dexter Hub
« Reply #10 on: February 14, 2009, 12:48:24 PM »
Is there a design on here showing how a brake disc can be placed on the spindle so an emergency brake caliper can be used to shut the rotor down using the dexter hub backside?
« Last Edit: February 14, 2009, 12:48:24 PM by imsmooth »
