Author Topic: Multiple in hand wire for coil windings  (Read 838 times)
DFIII
« on: May 06, 2009, 05:14:54 PM »
I was wondering if there was a conversion chart to figure out wire equivalents such as, what gauge would 2 22awg wires 2 in hand equal.
I would like to think that you just double the diamiter and check the chart but I don't believe that it really works that way.
« Last Edit: May 06, 2009, 05:14:54 PM by (unknown) »
Re: Multiple in hand wire for coil windings
« Reply #1 on: May 06, 2009, 11:41:28 AM »
The American AWG system results in a number 3 lower being twice the csa.
If you use 2 in hand #22 it is equivalent to a single #19.
I can't see what other virtue the scheme possess, everyone else uses diameter.
« Last Edit: May 06, 2009, 11:41:28 AM by Flux »
dbcollen
« Reply #2 on: May 06, 2009, 11:43:13 AM »
3 wire sizes equals twice the cross section, so if you need twice as big as 22g, you would use 19g.
Dustin
« Last Edit: May 06, 2009, 11:43:13 AM by dbcollen »
« Reply #3 on: May 06, 2009, 08:50:23 PM »
You multiply the diameter by the square root of two to double the cross section area.  Multiplying the diameter by two multiplies the area by four.
« Last Edit: May 06, 2009, 08:50:23 PM by Ungrounded Lightning Rod »
