Author Topic: Building rotors  (Read 1690 times)
bj
Building rotors
« on: May 26, 2009, 02:33:23 PM »
Got first two rotors built, so decided to mount them on the spindle,
and do a little coil testing.  They turned out nice and true, so I was
happy with them--until--aren't they supposed to attract each other?
Can't believe I made such a stupid mistake.  Good thing I am building
two ten footers, as I will still be able to use both of them.  That is if
I can cure this little brain disconnect that seems to be the problem.
bj
« Last Edit: May 26, 2009, 02:33:23 PM by (unknown) »
bj
Lamont AB Can.
Re: Building rotors
« Reply #1 on: May 26, 2009, 08:50:02 AM »
bj;
Do they repel each other?
If so, maybe you can offset rotors by an odd # of magnet spaces?
I had one that was doing that and all it took was rotating one rotor by a half turn [I think]. Its been awhile so maybe it was a quarter turn? I had pulled it apart to grease it and my grease pencil marks got munged by handling so I knew it was right once so may not apply to your situation. I now grind a divot on both rotor edges to avoid this problem in the future.
Good luck with it and hopefully its not a total wash.
« Last Edit: May 26, 2009, 08:50:02 AM by TomW »
Re: Building rotors
« Reply #2 on: May 26, 2009, 09:02:23 AM »
The only thing that may work is to red rill holes to compensate. Reuse for anothe unit is better.
« Last Edit: May 26, 2009, 09:02:23 AM by tecker »
Re: Building rotors
« Reply #3 on: May 26, 2009, 09:35:10 AM »
Depends on the number of fixing holes in relation to the number of magnets. There are some cases where turning one rotor will correct things. In other cases it doesn't work.
In this case it would be far more sensible to build the other two to suit but for a single machine it would need re drilling and all the problems associated with drilling a complete rotor with magnets on. It can be done but needs thought and care and in this case it is not a wise move.
« Last Edit: May 26, 2009, 09:35:10 AM by Flux »
kajs
Re: Building rotors
« Reply #4 on: May 26, 2009, 04:23:57 PM »
they not only should attract each other, but also neighboring magnets should be of opposite polarities facing up (upper sides of siblings must attract too)! it sounds that you have skipped that part.
« Last Edit: May 26, 2009, 04:23:57 PM by kajs »
bj
Re: Building rotors
« Reply #5 on: May 26, 2009, 10:00:27 PM »
Tom--thanks for good luck wish, all is not a total loss.  Twelve magnets
per rotor, so I could just redrill the holes one magnet over and it would
work, and I may do that, or just make an opposite pair, and then I will
have two working sets.
I think I made the mistake when putting magnets on the second disk.  Placed  one right, and noticed I had not made my witness mark on the second rotor, so took off the magnet and grilled in my mark.  Somehow must
have flipped it when I put it back.   The N,S,N,S orientation is correct
on both rotors, just one magnet out.  Like I said before,  DUMB.
Up side is that second set will be easier.
bj
« Last Edit: May 26, 2009, 10:00:27 PM by bj »
bj
Lamont AB Can.
bj
Re: Building rotors
« Reply #6 on: May 26, 2009, 10:07:16 PM »
Flux-- twelve magnets, four locating holes.  I can redrill the back rotor
one magnet over--40 degrees, or just make the second set as mirrors of the first two, but one magnet over.  Maybe I need a few less coffees in
the morning.  Couldn't believe the strength they had repelling each other.
When they are finally right, all the Dan's warnings will be well heeded.
thanks  bj
« Last Edit: May 26, 2009, 10:07:16 PM by bj »
bj
Lamont AB Can.
bj
Re: Building rotors
« Reply #7 on: May 27, 2009, 06:34:40 AM »
Typo--should read 30 degrees
bj
« Last Edit: May 27, 2009, 06:34:40 AM by bj »
bj
Lamont AB Can.
MattB
Re: Building rotors
« Reply #8 on: May 27, 2009, 06:58:32 AM »
um... if you have 12 magnets, and 4 bolt holes, you should have opposite groups of 3 magnets in relation to each bolt hole.. just rotate that rotor 90 degrees.
« Last Edit: May 27, 2009, 06:58:32 AM by MattB »
bj
Re: Building rotors
« Reply #9 on: May 29, 2009, 06:01:56 AM »
MattB  think my head has been in a dark smelly place the last few days,
you are absolutely correct. All is fine now-on to test coils.
Many thanks
bj
« Last Edit: May 29, 2009, 06:01:56 AM by bj »
bj
Lamont AB Can.
Re: Building rotors
« Reply #10 on: May 29, 2009, 06:54:56 AM »
Hehe.
Exactly as it was with mine when I reassembled it wrong.
Despite being funny looking Matt knows his stuff!
Glad you figured it out "the easy way".
Tom.
« Last Edit: May 29, 2009, 06:54:56 AM by TomW »
