Author Topic: Solar ceiling fan has been running 24 / 7  (Read 4266 times)
Basil
« on: June 04, 2009, 11:11:42 AM »
It has warmed up and the solar ceiling fan has been running 24 / 7. I pulled out the special controller I got Ghurd.to make for me a while back. I put it together and mounted it in an old HF controller box. It will shut off when the batteries get below 12.6 or near that. Turns back on at 13 volts. Like at night or low sunny days it will not keep pulling the batteries all the way down. I ask him to build this for me because I was tried of cutting the fan off and on manually.
It is working great so for. You can read my files to see what I have been doing. I have 290 watts of solar and 600 Ah's of batteries so for. Yes I got around to mounting the 2 100 watt panels I bought a while back. The next step is to make the fan go to half speed at night or off. Full speed it pulls 1.5 amps + or -some. I have half speed set at .75 amps. I also run my network hub and modem run off a 140 inverter. Also a lamp next to my computer at times. 600 Ah's pulls down faster than you think with this little load on it 24 / 7.
I love the 2 new panels I have seen 11 amps out of my solar array at times. The home made solar tracking is still working great. Prints to it is in my files also.
A special thanks to Ghurd.
« Last Edit: June 04, 2009, 11:11:42 AM by (unknown) »
Re: Solar ceiling fan has been running 24 / 7
« Reply #1 on: June 04, 2009, 10:20:15 AM »
Basil;
 That little controller is a handy little gem isn't it :].
« Last Edit: June 04, 2009, 10:20:15 AM by Bruce S »
TheCasualTraveler
« Reply #2 on: June 04, 2009, 10:32:42 AM »
     Why not dedicate 1 solar panel to the fan so the fan will run only when the sun is up and run faster with full sun, slower or off with less. Am I right in assuming it is a DC fan? The rest of the panels can go to your batteries.
« Last Edit: June 04, 2009, 10:32:42 AM by TheCasualTraveler »
« Reply #3 on: June 05, 2009, 06:02:38 AM »
Glad you are happy!
« Last Edit: June 05, 2009, 06:02:38 AM by ghurd »
Basil
« Reply #4 on: June 05, 2009, 07:04:40 AM »
 Hi TheCasualTraveler
Good idea but I run mine 24 / 7 unless the battries get low.
« Last Edit: June 05, 2009, 07:04:40 AM by Basil »
Basil
« Reply #5 on: June 05, 2009, 07:06:33 AM »
Hi Bruce S
Yes they are. I have plans to make use of more of them as I grow.
« Last Edit: June 05, 2009, 07:06:33 AM by Basil »
« Reply #6 on: June 05, 2009, 07:38:49 AM »
Basil;
   Cannot prove this yet, but I think G- made these things to be addictive. :-))
The more you find things to make work with these the more you find they can do,,,SOoo you then need another cause the little buggers are so handy.
See a trend here :))?
I currently have no less than 4 running at any one time!!
The man is out to be a dozenaire, then there'll be a mini_G- and we're in for it then!! He's out to take over Wallyworld
« Last Edit: June 05, 2009, 07:38:49 AM by Bruce S »
TheCasualTraveler
« Reply #7 on: June 05, 2009, 04:03:08 PM »
Sorry, misread your post. I thought you wanted the fan off at night.
     In that case sounds like another happy Ghurd customer.
I think it should have a better name than Ghurd's controller. Ghurd's Magic controller at very least.
Ghurd brand magic controllers.
Ghurds ultimate controller.
Ghurd's all-in-one magic controller.
The ultimate magic controller by Ghurd.
Endorsed by control freaks the world over!
It just keeps controlling, and controlling, and controlling...
« Last Edit: June 05, 2009, 04:03:08 PM by TheCasualTraveler »
« Reply #8 on: June 07, 2009, 12:57:27 AM »
I have a few products out in limited markets, and I can guarantee you that NONE of them have a decent name.
"Ghurd's controller" is about as good as it gets.  :(
« Last Edit: June 07, 2009, 12:57:27 AM by ghurd »
Basil
« Reply #9 on: June 07, 2009, 05:13:21 AM »
Here is a HF Controller at it's best. It is now a FAN Controller.
I wired it to the termainals going out the back. BAT to BAT. Solar to Fan. Asyou can see I am useing clip on wires for now until I put it all together.
It is 6 AM and you can see the controller is on but the other led is off. The fan shut down durring the night just like it should. I have got to come up with a better and smaller speed control. This is what I am useing now.
Hook up to one end and find the sweet spot in the center for the current draw you need. I need something I can put in the old HF / New FAN Controller housing.
« Last Edit: June 07, 2009, 05:13:21 AM by Basil »
« Reply #10 on: June 07, 2009, 07:46:12 AM »
Hehe, not much at naming stuff my dog is simply "buddy" because thats what he is my "buddy".
Anyway, I suggest you call it "Glens Revenge" or something totally off the wall such as . Hurd Solar Super Controller 3G. Guaranteed to give you the control you need.
It can and does control anything you need control of , spouses, children, dogs, cats, wind turbine, solar, vortex generator, whatever. Simple, easy, cheap. Not available in stores. While supplies last. Call now!
Please see our disclaimer for full details.
Ha, I am working up a name for it. One of those self referencing acronyms I think is in order. ;=>
My fee will be one share of stock when you go public. Either that or a buck two ninety eight now.
« Last Edit: June 07, 2009, 07:46:12 AM by TomW »
TheCasualTraveler
« Reply #11 on: June 07, 2009, 09:07:02 AM »
Perhaps this is a good option for the monthly poll.
     We make suggestions, put them in a poll, and vote on it.
Subject to the owners approval.
« Last Edit: June 07, 2009, 09:07:02 AM by TheCasualTraveler »
