Author Topic: VAWT Road Test  (Read 2091 times)
(unknown)
VAWT Road Test
« on: August 06, 2009, 11:09:16 PM »
Test showed max RPM's where reached at low speed and remained stable and constant as speed increased.
Test also showed the need to reconfigure alternator to produce a higher output at a lower RPM's.
Video link:
http://www.youtube.com/watch?v=NhWzOf9thDI
« Last Edit: August 06, 2009, 11:09:16 PM by (unknown) »
Re: VAWT Road Test
« Reply #1 on: August 06, 2009, 06:48:33 PM »
Best idea:  Renting a truck for 20 bux, buying the "all dings are prepaid" insurance option, and using THAT instead of your OWN vehicle (in case the mill throws a blade).
« Last Edit: August 06, 2009, 06:48:33 PM by Ungrounded Lightning Rod »
Re: VAWT Road Test
« Reply #2 on: August 06, 2009, 08:15:40 PM »
Hi KilroyOdin.
I've done several years of truck mounted wind testing myself.
When I've reported my test #s here I got alot of critisizem for my scewed mph#s.
Wind excelerates over the cab, exsisting wind condidtions and all that.
I have a wind tunnel now and the #s are way diferant.
« Last Edit: August 06, 2009, 08:15:40 PM by Jerry »
commanda
Re: VAWT Road Test
« Reply #3 on: August 07, 2009, 01:08:50 AM »
I would have a play with the angle the blades are mounted, see if you can improve the max rpm before it stalls?
« Last Edit: August 07, 2009, 01:08:50 AM by commanda »
KilroyOdin
Re: VAWT Road Test
« Reply #4 on: August 07, 2009, 03:34:51 AM »
Hi, it was a very claim day and I was using a hand held anemometer and the wind speed being measured was about the  same as the dash board MPH gauge. I was surprised.
« Last Edit: August 07, 2009, 03:34:51 AM by KilroyOdin »
Re: VAWT Road Test
« Reply #5 on: August 07, 2009, 08:35:49 PM »
Were you holding the anemometer near the middle of the blades on the turbine or out the window?
« Last Edit: August 07, 2009, 08:35:49 PM by Ungrounded Lightning Rod »
KilroyOdin
Re: VAWT Road Test
« Reply #6 on: August 08, 2009, 06:28:35 AM »
I riding in the back of truck and took the reading in front of the turbine.
« Last Edit: August 08, 2009, 06:28:35 AM by KilroyOdin »
