Author Topic: The ongoing saga of my seventeen footer  (Read 1630 times)
fabricator
  • My smoke got out again
« on: February 03, 2010, 07:02:27 AM »
This is a piece of 1/4 x 1 stainless flat stock rolled into a 16.5 inch ring tig welded to the back side of the rear rotor, I intend to build a clamp type caliper that will be cable operated, it will be able to be applied slowly to avoid sudden jerks, it will also be able to be updated to some kind of automated operation in the future, I will keep updating as it progresses.
« Last Edit: February 03, 2010, 07:02:27 AM by (unknown) »
tanner0441
Re: The ongoing saga of my seventeen footer
« Reply #1 on: February 03, 2010, 10:49:42 AM »
Hi
Looks like a very neat job the SS ring looks the same colour as the rotor, Is the rotor stainles as well?
Brian
« Last Edit: February 03, 2010, 10:49:42 AM by tanner0441 »
fabricator
« Reply #2 on: February 03, 2010, 11:35:12 AM »
No the rotor is cold rolled steel.
« Last Edit: February 03, 2010, 11:35:12 AM by fabricator »
tanner0441
« Reply #3 on: February 03, 2010, 01:14:32 PM »
Hi
I am impressed with the welding I used to do all the welding at my last employer, marine applications, stainles, aluminum etc, what shielding gas did you use? For stainless we used helium you had to be careful not to loose the arc it gave better penetration, but stainless to a standard steels you had to be careful not to get stress cracks on the weld ends.
Brian
« Last Edit: February 03, 2010, 01:14:32 PM by tanner0441 »
fabricator
« Reply #4 on: February 03, 2010, 03:14:20 PM »
I use just straight argon, with stainless 309 filler rod it is less likely to crack when welding to dissimilar metals.
« Last Edit: February 03, 2010, 03:14:20 PM by fabricator »
freejuice
« Reply #5 on: February 03, 2010, 04:40:23 PM »
Looking good!
« Last Edit: February 03, 2010, 04:40:23 PM by freejuice »
