Author Topic: Help needed  (Read 2846 times)
loonie
Help needed
« on: February 20, 2010, 11:37:04 AM »
Hi I was recently given a whisper 600 back from the world power days. Electricly it tested fine but had bad bearings. stripped it down, cleaned it up, and replaced bearings. While putting it back together I would like to replace the brushes. Of course swwp dosnt have parts and no longer supports the older modles. I havent been able to find anything like this on the internet, (or something simmular) that might work. Does anybody here have any idea where to get solder on brush pads or other ideas that might work?  Thanks (trying to attach page from manual) I cna't seem to attach it here, I did upload it to my files but only shows in my photo uploads, not in my files. Please help admin. I will try again later.
 Loonie
there you go
Kurt
« Last Edit: February 20, 2010, 11:37:04 AM by (unknown) »
loonie
Re: Help needed
« Reply #1 on: February 20, 2010, 12:44:27 PM »
THANK YOU KURT !!
« Last Edit: February 20, 2010, 12:44:27 PM by loonie »
FishbonzWV
Re: Help needed
« Reply #2 on: February 20, 2010, 01:21:04 PM »
Don't have any idea if this will help but a quick search found this.
http://www.southlandelectric.com/contact_kits.htm
Googled: contactor replacement parts
Bonz
« Last Edit: February 20, 2010, 01:21:04 PM by FishbonzWV »
H.F.Fisher 1925-2007
fabricator
  • My smoke got out again
Re: Help needed
« Reply #3 on: February 20, 2010, 01:26:23 PM »
Is the brush material worn thin? What do the brushes run on? Brass rings?
« Last Edit: February 20, 2010, 01:26:23 PM by fabricator »
loonie
Re: Help needed
« Reply #4 on: February 20, 2010, 01:38:37 PM »
Hi, Slip rings seem to be brass, brushes seem to be carbon on cooper so it can be soldered on. The carbon is getting thin.
« Last Edit: February 20, 2010, 01:38:37 PM by loonie »
loonie
Re: Help needed
« Reply #5 on: February 20, 2010, 01:43:19 PM »
Thanks, a search of there site didn't come up with any brushes. Seems to be mostly contactors for motor starters and switchgear.
« Last Edit: February 20, 2010, 01:43:19 PM by loonie »
tanner0441
Re: Help needed
« Reply #6 on: February 20, 2010, 02:05:41 PM »
Hi
Would it be posible to use ordinary brushes filed to size and bonded on with coloidial silver epoxy.
Brian
« Last Edit: February 20, 2010, 02:05:41 PM by tanner0441 »
Re: Help needed
« Reply #7 on: February 20, 2010, 02:44:27 PM »
Might try taking one of the sets to a motor shop.
It may be a semi-common, or only semi-obscure, brush.
Or they may be able to figure something out with what is available.
« Last Edit: February 20, 2010, 02:44:27 PM by ghurd »
bob g
    • microcogen.info
Re: Help needed
« Reply #8 on: February 20, 2010, 03:49:37 PM »
if all else fails
take a new brush, from something bigger
carefully with a specially prepared hacksaw blade or a dremel tool
cut a groove on each side of the brush
then from a hobby shop or maybe a scrap piece of copper sheet, cut out
the backing plates and leave enough to foldup and into the grooves in the brush
then carefully tweak down the excess to trap the brush and lock it to the backing copper backing plate
tin and sweat to  your old support arms.
if it were me i would make them slightly larger to get more friction area.
if i knew how to post a picture or rather a jpeg i could illustrate the process
much easier, a pic worth a 1000 words as they say.
bob g
« Last Edit: February 20, 2010, 03:49:37 PM by bob g »
fabricator
Re: Help needed
« Reply #9 on: February 20, 2010, 03:58:39 PM »
If it were me I'd polish up the brass rings and put it together, the carbon likely wears at a very slow rate, check them in a year and see if there is any wear.
« Last Edit: February 20, 2010, 03:58:39 PM by fabricator »
bob g
    • microcogen.info
Re: Help needed
« Reply #10 on: February 20, 2010, 04:16:35 PM »
maybe this will work, i have no clue how to post a jpeg to the forum
http://www.fieldlines.com/user/bob%20g/files
bob g
« Last Edit: February 20, 2010, 04:16:35 PM by bob g »
Re: Help needed
« Reply #11 on: February 20, 2010, 04:43:26 PM »
If someone types how to do it, it gets goofy...
So here is a image of the text.  :)
Be sure to preview it, sometimes it gets goofy anyway.
« Last Edit: February 20, 2010, 04:43:26 PM by ghurd »
bob g
    • microcogen.info
Re: Help needed
« Reply #12 on: February 20, 2010, 06:07:51 PM »
good lord, no wonder i can't get a picture uploaded!
gonna be nice when the day finally comes that this place morphs over to SMF
hint, wink, nod, kick!!
bob g
« Last Edit: February 20, 2010, 06:07:51 PM by bob g »
Re: Help needed
« Reply #13 on: February 20, 2010, 06:59:42 PM »
"gonna be nice when the day finally comes that this place morphs over to SMF"?
Maybe for you young-uns, but I just learned how to work this one.  :(
« Last Edit: February 20, 2010, 06:59:42 PM by ghurd »
thirteen
Re: Help needed
« Reply #14 on: February 20, 2010, 10:26:25 PM »
maybe a local altinator repair shop might help. Just an idea.
« Last Edit: February 20, 2010, 10:26:25 PM by thirteen »
MntMnROY 13
loonie
Re: Help needed
« Reply #15 on: February 21, 2010, 06:25:39 AM »
Thanks for all the replies, I'll post when I get it finished.
Gary
« Last Edit: February 21, 2010, 06:25:39 AM by loonie »
bob g
    • microcogen.info
Re: Help needed
« Reply #16 on: February 21, 2010, 09:19:46 AM »
thanks for the helping hand Ghurd
i have about every last brain cell already heavily committed to other duties, and
prying a few away to learn how to post pics to this forum when i know that eventually
they will be changing platforms is just not something i am willing to do..
but i appreciate your help!
bob g
« Last Edit: February 21, 2010, 09:19:46 AM by bob g »
