Author Topic: water air conditioner  (Read 1259 times)
rubiconone
« on: August 08, 2005, 02:09:14 AM »
My idea is to circulate water through a 2" copper pipe 4' below ground level for a yet to be determined distance then back into the house. There it will enter a very large radiator that is enclosed inside the existing home vent system. Behind the radiator will be a fan that will pass the air through the radiator and vent system.The air will circulate through the homes vent system before returning through the return vents where start the process again. The water likewise will exit the radiator through the other end of the copper pipe and then a small water pump will circulate the water under ground before returning to the radiator. The only power consumption will be a small water pump and large fan system. Will it work and what are the problems?
thank rubicone
« Last Edit: August 08, 2005, 02:09:14 AM by (unknown) »
