Author Topic: solar water heater to heat yor home ??  (Read 3636 times)
xboxman
« on: October 26, 2004, 09:00:46 AM »
how about using a solar water heater and have a radiator in side the house to heat the house or at least heat one room ... any ideas on this ??
« Last Edit: October 26, 2004, 09:00:46 AM by (unknown) »
dudevato
Re: solar water heater to heat yor home ??
« Reply #1 on: October 26, 2004, 11:16:51 AM »
I have a solar batch water tank that supplies my garden shower that I am Very Happy with. I'm kicking around putting together a panel air heater, or 2, to heat my shop. This will have a PV cell to power the small fan that will circulate the air. I'm no design/tech wizard but would think it would be an easier/cheaper/smaller project to put together an 'air panel'  Go back over past postings, there are a number of links/pics that will have you laying awake at night, thinking.  Good Luck.
« Last Edit: October 26, 2004, 11:16:51 AM by dudevato »
dvdapex
« Reply #2 on: January 26, 2005, 09:56:42 AM »
I have a plan to make a 4x8 solar water heater.  I would then like to run the water through the attic (with insulation around the pipes--of course) through an old radiator in our living room to provide extra warmth during the winter.  Unfortunately, I live in WI and the winters here would surly freeze the water.  So, I was thinking about using used vegetable oil (get it from a nearby restaurant and strain it) instead of water.  I'd also read that anti-freeze is less effective after only 2-3 years.  I would prefer to make a sealed system so I'd like to shy away from using this.
Here are some questions/concerns:
  1. What size copper pipes should I use to run the oil through?
  2. The return portion of the pipe would have about a 5 foot (gradual) incline.  Can convection do this or do I need a pump?
  3. Is there any concern of pressure build-up in the pipes?
  4. Is there any reason to stick with water or water with anti-freeze?
  5. Do I fill the pipes 100% or less to account for some expansion of the liquid?
Thanks in advance.
« Last Edit: January 26, 2005, 09:56:42 AM by dvdapex »
rain1224
  • Country: cn
« Reply #3 on: April 05, 2012, 09:00:28 PM »
Solar heat is very popular today, for it is environmental and its recyclability, we can protect the earth at the same time.
"Link Removed"
DO NOT POST LINKS THAT ADVERTISE
« Last Edit: April 06, 2012, 09:48:42 AM by Bruce S »
Watt
« Reply #4 on: April 05, 2012, 10:15:14 PM »
Wow, that's diggin' up old threads.  An inverter link?
Watt sorry I took the night off for face to face time with the wife  8),
I removed the link.
« Last Edit: April 06, 2012, 09:49:44 AM by Bruce S »
