Author Topic: goodman A24-10 question  (Read 5111 times)
xboxman
« on: March 10, 2005, 10:38:33 PM »
i have a goodman A24-10 AIR HANDLER  i want to hook up the ac to this model does any one know what all i need to do this ? is there an out side unit i need to get for the ac to work ? and about what price is it ?
thanks terry
« Last Edit: March 10, 2005, 10:38:33 PM by (unknown) »
deerslayer660
Re: goodman A24-10 question
« Reply #1 on: March 10, 2005, 04:59:09 PM »
   not enough info there  do you have a forsced air furnace now?  if so you dont need a air handler as the furnace dos this  you will also need a complete aircond
sys coil condencer line sets wire to box exc  george    ps about 1300$ more stuff
george
« Last Edit: March 10, 2005, 04:59:09 PM by deerslayer660 »
drysider
« Reply #2 on: March 22, 2005, 12:23:07 PM »
You have a Goodman air handler with a 2 ton A/C coil mounted in it, along with a 10KW electric heat module. You will need a 2 ton outdoor condensing unit and the associated piping and wiring to get the A/C going. If you use a Goodman outdoor unit, the wiring will be a lot easier.
Pat
« Last Edit: March 22, 2005, 12:23:07 PM by drysider »
