Author Topic: Wood Chip Stove  (Read 20260 times)
mustang19432001
Re: Wood Chip Stove
« Reply #33 on: November 19, 2007, 07:01:16 AM »
Place=plate
« Last Edit: November 19, 2007, 07:01:16 AM by mustang19432001 »
12AX7
Re: Wood Chip Stove
« Reply #34 on: November 19, 2007, 10:28:16 PM »
Hello Mustang
What ever the size of the wood chips, the "cup" (hole) has to be large enough that the chips can both enter (and most likely momentarily staged) and then "dropped".  Filling these holes/cups with a somewhat consistent amount may prove to be tricky.  Then add to the problem that this same revolving plate/disk/cylinder will need it's cup to "dump" into another "hole" (the entrance to the fire pot).
I've worked with industrial packaging system (volumetric fillers) where the "target" hole was elongated to maximize the time the fill cup passes over it (giving the product)  a "longer" chance to dump/empty completely.
I'd suggest a "larger" diameter shorter "depth" rather than the other way.
Also keep in mind the need for some "adjustment"   Be it adjusting the speed of the rotating plate/disk and/or some adjustment of the "cup" volume (by adjusting the depth of cup).
For my own (mostly un-started) project I keep coming up with more issues/problems than solutions.  But NOT given up.  There's a lot of "crap" being sold out there,  and they want a lot of money for it.  It shouldn't be real hard to build, once all the bugs are worked out.
Perhaps you should also consider how/where you will store the wood chips.  (I know some who have used two tons of pellets in a season)
Been keeping my eye open for an old woodstove to use as a "prototype".
Keep chippin away!
« Last Edit: November 19, 2007, 10:28:16 PM by 12AX7 »
mustang19432001
Re: Wood Chip Stove
« Reply #35 on: November 23, 2007, 10:02:21 PM »
one idea that occurred to me is using a scoop wheel much like what is used to load up a soft serve cone with jimmies at the ice cream parlor. As the wheel spins the scoops on the bottom scoop up the chips and when they reach the top gravity drops them into a funnel shaped shoot where they are then dropped into the burn pot. As long as the wheel does not scoop directly into the pile it should be fine. Have the hopper pour into the wheel with little agitators to prevent jamming.
That's another thing I've been thinking about. Where the fire pot would be a firebrick pot with either holes drilled in the bottom for air to flow up into the pot. Or kept simple without holes and air would be blown in from the back. Even if there is a little ash buildup at least it will fill in a corner gaps and make for a smoother air flow.
« Last Edit: November 23, 2007, 10:02:21 PM by mustang19432001 »
