Author Topic: SouthWest by SouthEast  (Read 1419 times)
Kevin L
« on: August 20, 2007, 05:38:11 PM »
I have been considering building a solar air space heater for some time.  The major holdup is the direction the house is pointed.  The house has 2 walls that are exactly 45 degrees from south.  Are there any tables or charts that would list the % heat lost / m2 due to reflection in this situation?  Thanks
« Last Edit: August 20, 2007, 05:38:11 PM by (unknown) »
GaryGary
    • Build-It-Solar
Re: SouthWest by SouthEast
« Reply #1 on: August 20, 2007, 11:56:02 AM »
A collector pointed SE or SW does pretty well.
I pasted in a couple runs from Radiation On Collector below.
The first is for a vertical collector pointed due south.
The 2nd is for a vertical collector pointed SE  (a collector pointed SW would give the same results).
The last column (labeled Total) is the total solar radiation on the collector for a full sunny day per square foot of collector.
It looks like the SE and SW collectors are down about 20% from a south collector in mid-winter.  You could just use more area to make up for this.
Here is an interesting excerpt from the Shurcliff book on the 45 degree oriented house/collector/reflector:
http://www.builditsolar.com/Experimental/ShurcliffPart1/S89pt5.htm
I guess its obvious, but SE will give you more morning heat and SW will give you more afternoon heat.  Most people like the morning orientation.
Of course, you could use both.
This is the simple, cheap solar air collector I use on my shop -- 1 year payback where we live:
http://www.builditsolar.com/Projects/SpaceHeating/solar_barn_project.htm
You can download Radiation On Collector here:
http://www.builditsolar.com/Tools/RadOnCol/radoncol.htm
Collector pointed due south (ideal):
Month by Month Summary of Sun on Collector
(100% sunny weather)
  Collector Area:        1.0 (sqft)
  Collector Azimuth:     0.0 (deg) measured from South
  Collector Tilt:       90.0 (deg) measured from horiz
  Latitude:             42.0 (deg)
  Altitude above SL:     0.0 (ft) Above Sea Level
Date ----  Sun ----------------  Collector -----------------------
Month Day  Direct   Di-   Total    Direct      Difuse     Total
           Normal   fuse
   1   21   2099     122   2221       1629         61       1690
   2   21   2525     151   2677       1663         76       1739
   3   21   2887     205   3092       1424        102       1527
   4   21   3094     301   3396        928        151       1079
   5   21   3179     386   3565        591        193        783
   6   21   3217     430   3647        459        215        674
   7   21   3080     419   3499        559        209        769
   8   21   2912     354   3266        868        177       1045
   9   21   2684     249   2933       1318        125       1443
  10   21   2355     171   2526       1573         85       1658
  11   21   2026     127   2153       1580         64       1643
  12   21   1845     106   1951       1517         53       1570
Sum        31904    3022  34926      14109       1511      15620
Radiation in BTU/day
Collector pointed SE (or SW):
  Collector Azimuth:    45.0 (deg) measured from South
  Latitude:             40.0 (deg)
           Normal   fuse
   1   21   2192     127   2320       1203         64       1267
   2   21   2600     156   2756       1279         78       1357
   3   21   2917     207   3124       1219        104       1323
   4   21   3095     302   3397       1023        151       1173
   5   21   3162     384   3545        836        192       1027
   6   21   3181     426   3607        752        213        964
   7   21   3061     416   3477        799        208       1007
   8   21   2914     354   3268        956        177       1133
   9   21   2713     252   2966       1127        126       1253
  10   21   2429     176   2605       1202         88       1290
  11   21   2121     133   2254       1168         67       1235
  12   21   1974     113   2087       1134         57       1190
Sum        32359    3046  35404      12697       1523      14220
« Last Edit: August 20, 2007, 11:56:02 AM by GaryGary »
« Reply #2 on: October 02, 2007, 02:28:21 PM »
You may want to put your panel on the SE side, or put a big one there and a smaller one on the SW.
The SE collector will produce max heat in the morning, when the house is cold from the night and needs to be brought back up.  The SW collector will max out in the afternoon, when you're probably only need to maintain your temperature rather than raise it - or may already be too hot.
« Last Edit: October 02, 2007, 02:28:21 PM by Ungrounded Lightning Rod »
