Author Topic: air to water [CLOSED]  (Read 1410 times)
windspeed
« on: May 20, 2008, 09:14:51 PM »
has  anyone got any experience or opinions on this heating system it extracts heat from the outside air using a refrigerant even at below freezing temperatures
an example of the system can be viewed here
http://www.dimplex.de/en/heat-pumps/air-to-water.html
windspeed
Try to do some research, this is ancient technology.
It is not DIY nor has anything to do with making your electricity from scratch. Which is the purpose of this forum.
Asking questions on this forum is NOT research.
« Last Edit: May 20, 2008, 09:14:51 PM by (unknown) »
wdyasq
Re: air to water
« Reply #1 on: May 20, 2008, 03:24:04 PM »
Hey windspeed,
It is known as an 'air source heat pump'. I saw my first one over 30 years ago.
Do a bit of research....... or, do you use forums instead of a library/internet?
« Last Edit: May 20, 2008, 03:24:04 PM by wdyasq »
