Author Topic: bore and tidal river and Questions??  (Read 1562 times)
free life
« on: October 23, 2004, 11:25:23 PM »
Hi
Getting started.
I have a bore 12 to 15 feet to the water about thirty feet deep.
Theres a river but it is tidal.
Is there something that fits this problem to make power?
Is there away of drawing the bore water up to run a turbine?
Or will I stick with the wind and solar set up if it can make enough power?
Free life
« Last Edit: October 23, 2004, 11:25:23 PM by (unknown) »
Re: bore and tidal river and Questions??
« Reply #1 on: October 24, 2004, 06:00:06 AM »
   Interesting idea for dump load to pump water during off peek times to a cistern
until you have enough to run a water turbine.
« Last Edit: October 24, 2004, 06:00:06 AM by tecker »
bill541
« Reply #2 on: October 24, 2004, 01:22:40 PM »
I'm not sure where the bore comes into play here, is it a borehole you are referring to? If so, do the tidal movements change the level of water in the bore?
The tidal flow of the river may have some possibilities for a low head hydro provided you could place a dam or diversion in it.
You may want to post some more detailed information to get better input.
-Bill-
« Last Edit: October 24, 2004, 01:22:40 PM by bill541 »
free life
« Reply #3 on: October 25, 2004, 04:10:17 AM »
It is a borehole and no the tidal movement make's no diff... to it as it is over two hundred feet from the river.
I am right near the mouth of the river so slit and weed would all play apart in problems of getting water to run.
Even a pipe line keeping it free of crabs snails and so on .
The river is over 400ft wide at full tide and splits into two at low.
I will shot some levels at some time just to see the fall over 100 yards or less.
I am starting to lean to wind unless someone can turn the tide so to speak.
Free life
« Last Edit: October 25, 2004, 04:10:17 AM by free life »
free life
« Reply #4 on: October 25, 2004, 04:15:31 AM »
How big of cistern or tank would I need ?
until I have enough to run a water turbine.
« Last Edit: October 25, 2004, 04:15:31 AM by free life »
