Author Topic: Scaleable water powered engine  (Read 1556 times)
Xavy
« on: July 23, 2004, 09:55:35 AM »
These are simply thoughts of a non intrusive method to capture the power of water flowing downhill...Please take a moment to consider the possibility of such a scalable engine powered by water.  First go to the following link and view the concept of using buoyancy to lift weight.  Refer to the last drawing at the end of the article.  I say scalable because ships are lifted through the Panama Canal using the same principal.  http://debateusa.com/debate/viewtopic.php?t=1337
Now go to the below site and view an animation of the old John Deere two cylinder engine and how it functions.  If you turn the animation clockwise on quarter turn and connect the two concepts in your mind you have a scaleable water engine. http://my.voyager.net/~vinsond/jd_animation.html
Please note the original drawling describes a storage tank however for a large scale power source a stream could be routed through step tanks similar to the Panama canal to achieve the same action.  The exhaust valve would evacuate (cause to flush) the water to the next tank.
An after thought I had considered instead of the buoyancy pushing they could be tethered to a pulley at the bottom of the tank and transfer the power through linkage connected to relative levers to propel the crankshaft connecting rods.
« Last Edit: July 23, 2004, 09:55:35 AM by (unknown) »
kirk
Re: Scaleable water powered engine
« Reply #1 on: July 23, 2004, 11:09:39 AM »
http://www.du.edu/~jcalvert/tech/fluids/hydstat.htm has a photograph of a water motor built by Trevithick. Unfortunately it doesn't show enough to make the mechanism apparent.
It was a double acting cylinder with a valve operated at the ends of the stroke. If run slowly I believe it would be more efficient than a Pelton wheel.
« Last Edit: July 23, 2004, 11:09:39 AM by kirk »
Xavy
« Reply #2 on: July 23, 2004, 01:31:21 PM »
Thanks for the link.  I found another link with good information also at http://www.homepower.com/magazine/downloads_hydro_power.cfm which includes pictures and drawings.  It is more like a turbine though.  Again thanks again for the link I'll read it in detail later.
« Last Edit: July 23, 2004, 01:31:21 PM by Xavy »
