Author Topic: Viktor Schuaberger water power  (Read 1583 times)
hobot
« on: March 25, 2005, 06:00:07 AM »
One can get real far out with vortex engery but this
is for the down and dirty concentration of water power
by velocity rather than pressure head.
http://www.frank.germano.com/waterpower.htm
« Last Edit: March 25, 2005, 06:00:07 AM by (unknown) »
finnsawyer
Re: Viktor Schuaberger water power
« Reply #1 on: March 25, 2005, 08:58:08 AM »
As I pointed out in the past a similar effect occurs for air flowing around or being concentrated by an object.  The drop in pressure as the air speeds up allows, in principle, for more energy to be extracted (Bernoulli's Equation).  The only question, as I see it, is backward pressure from the turbine.  Apparently it is not a problem.
« Last Edit: March 25, 2005, 08:58:08 AM by finnsawyer »
hobot
« Reply #2 on: March 25, 2005, 09:42:32 PM »
I'll play in my spring branch and big creek someday
but in my case my big interest is air intake tracks in
old motorcycle head and combustion chamber turbulence
at pressures the gas is more viscous than water.
In somewhat related fluid flow vien, are foil bearings that
float on air I'm hoping to adapt to crankshaft use.
On the stream flow restrictions I've seen some neat
things like rocks being thrown out of cascades onto
far bank several yards higher than water level. Also seen
series of alternation rotation bowls craved in otherwise
flat rock water 'slides'. Don't know what to make of it
all myself so just offering up stuff that may connect
with someone.
hobot
« Last Edit: March 25, 2005, 09:42:32 PM by hobot »
