Author Topic: newbie hydro  (Read 1499 times)
zjduncan50
newbie hydro
« on: December 09, 2008, 01:18:43 AM »
I'm new to this. I have a spring fed pond that has a constant run off. I can get 13' of head w/100-150 gpm. I thought building a banki turbine was the only way to go until reading some of your postings. Suggestions?
« Last Edit: December 09, 2008, 01:18:43 AM by (unknown) »
Re: newbie hydro
« Reply #1 on: December 08, 2008, 07:47:00 PM »
                     http://www.otherpower.com/scotthydro1.html
« Last Edit: December 08, 2008, 07:47:00 PM by hiker »
Re: newbie hydro
« Reply #2 on: December 09, 2008, 02:14:32 AM »
For home build a Banki is probably your best option. You are well within range of a Turgo or even a Pelton with the modern low speed alternators with neo magnets. you don't have enough flow for a reaction turbine to be a realistic proposition although a simple propeller turbine might work if you can keep all the muck out of it.
Unless you have good engineering facilities or are prepared to buy a rotor i think the Banki is your best option.
« Last Edit: December 09, 2008, 02:14:32 AM by Flux »
Re: newbie hydro
« Reply #3 on: December 09, 2008, 03:24:11 AM »
on site and putting out some watts[banki]
« Last Edit: December 09, 2008, 03:24:11 AM by hiker »
spinningmagnets
Re: newbie hydro
« Reply #4 on: December 09, 2008, 09:52:35 AM »
I hope to own a home with a hydro site someday. Unlikely, but...
Banki is a proven generator with your conditions, certainly the first option for consideration. Also very low up-front cost.
If you are willing to build a small pond and flume, with a 7'-10' drop tube, a Kaplan may be viable.
http://www.fieldlines.com/story/2008/6/22/191210/965
« Last Edit: December 09, 2008, 09:52:35 AM by spinningmagnets »
