Author Topic: FSP 62556 1/2HP for hydro genny sans magnets?  (Read 1456 times)
ignesandros
« on: October 11, 2005, 03:57:02 PM »
I recently came into possession of a FSP 62556 1/2HP AC induction motor from an older Maytag washer. What would I have to do to utilize this in its current state as a generator for use in a hydro power experiment? Specifically, without adding any magnets, is it capable of producing power? I've heard something about using capacitors and a controller. I'd like to give it a try.
Also, is it feasible to make it submersible?
-Andrew
« Last Edit: October 11, 2005, 03:57:02 PM by (unknown) »
Re: FSP 62556 1/2HP for hydro genny sans magnets?
« Reply #1 on: October 11, 2005, 02:31:09 PM »
Small single phase motors are not always satisfactory as induction generators.
Try spinning it at its rated speed or a bit higher and keep adding capacitance across its run winding. If you get to 120uf and it still hasn't excited you are probably out of luck.
If it does excite, use the smallest capacitor that makes it excite at about 10% below rated speed.
You will not have a very wide speed range over which it will operate, it will be very inefficient on light load and not particularly good on full load.
To make it submersible that is a major project and pigs may fly first.
« Last Edit: October 11, 2005, 02:31:09 PM by Flux »
nickelbender
« Reply #2 on: October 15, 2005, 09:54:40 PM »
I've seen a pig a or two fly just to spite me.....
A modified submersable pump might be what he's looking for .
« Last Edit: October 15, 2005, 09:54:40 PM by nickelbender »
ignesandros
« Reply #3 on: October 26, 2005, 08:08:43 AM »
Hehe, I do have a 1/3HP sump collecting dust. :)
« Last Edit: October 26, 2005, 08:08:43 AM by ignesandros »
