Author Topic: Penstock Question  (Read 1472 times)
MaxFlow
Penstock Question
« on: October 31, 2005, 02:38:26 PM »
Although penstocks that I have seen usually run downhill fairly straight, has anyone contemplated running it in concentric loops downhill, I realize the cost would be much greater, but with the greater pressure of having more water between the resevoir and the powerhouse, would it improve the force?
« Last Edit: October 31, 2005, 02:38:26 PM by (unknown) »
wdyasq
head
« Reply #1 on: October 31, 2005, 07:54:05 AM »
Pressure is measured in distance top of water pool to discharge point.  ANY pipe lowers that figure. Longer pipe means less flow.
Please do a bit of research before asking quesions.
« Last Edit: October 31, 2005, 07:54:05 AM by wdyasq »
MaxFlow
Re: Penstock Question
« Reply #2 on: October 31, 2005, 08:18:16 AM »
I did look for the answer but couldn't find one.
« Last Edit: October 31, 2005, 08:18:16 AM by MaxFlow »
hobot
« Reply #3 on: October 31, 2005, 06:52:53 PM »
Max,
You should keep looking further, as the short correct answer was
given, head or height holds power potenital , not the mass of water,
any extra pipe = friction, pressure or flow lowering power rubber.
Idealy a nozzle straight out the bottom of a tank, pond, lake etc into
the turbine would be best, an expensive drilling mining operation
than most would afford to do.
A filled pipe trades gravity and flow for pressure which is then
converted back to motion by the nozzle and then into torque via the
wheel.
Another asspect that few tap but has more potential is the flow speed
of the water for its momentum plus gravity engergy to act. A fairly
large pipe or tough is funneled down to use. Clean shot down hill is best
for this too.
hobot
« Last Edit: October 31, 2005, 06:52:53 PM by hobot »
MaxFlow
« Reply #4 on: October 31, 2005, 09:16:58 PM »
Thanks, this post can be deleted.
« Last Edit: October 31, 2005, 09:16:58 PM by MaxFlow »
