Author Topic: Submerged spiral turbines for hydro capture  (Read 1504 times)
ignesandros
« on: September 05, 2005, 07:12:26 AM »
I plan to produce a 4ft long by 8" diameter spiral using a sheet of medium density plastic I scavenged as a sort of submersible turbine to use in a drainage causeway with some boards to concentrate the flow. Is this worth trying? Last rainstorm, I figured the water was traveling roughly 10ft/s, or about 12,000GPM across the causeway.
I plan to use this specifically for powering a bilge pump to empty leaking water out of a basement in times of heavy rains, so the fact the drainage causeway will be dry half the time is no problem.
-Andrew
« Last Edit: September 05, 2005, 07:12:26 AM by (unknown) »
jlt
Re: Submerged spiral turbines for hydro capture
« Reply #1 on: September 05, 2005, 05:00:39 AM »
here is one that floats on the surface.
« Last Edit: September 05, 2005, 05:00:39 AM by jlt »
ignesandros
« Reply #2 on: September 08, 2005, 03:22:46 PM »
That appears to be more a shaft with fins at intermittent lengths. I had something in mind that might resemble an auger.
-Andrew
« Last Edit: September 08, 2005, 03:22:46 PM by ignesandros »
french town
« Reply #3 on: September 14, 2005, 05:01:22 PM »
 look at the ampair lvm. look at water wheel .com you have power this may show you the way.
                  never stop trying,  Sam
« Last Edit: September 14, 2005, 05:01:22 PM by french town »
