Author Topic: affordable kaplin turbine ??  (Read 2085 times)
hap
« on: January 16, 2006, 05:31:10 PM »
(blank)
« Last Edit: January 16, 2006, 05:31:10 PM by (unknown) »
Kwazai
Re: affordable kaplin turbine ??
« Reply #1 on: January 16, 2006, 11:47:02 AM »
are you looking to buy one or DIY?
DIY would be to use an hvac fan unit -there is a page somehwere around here with one thrown across a creek to charge batteries. I don't have the link.
Mike
« Last Edit: January 16, 2006, 11:47:02 AM by Kwazai »
hap
« Reply #2 on: January 16, 2006, 12:15:25 PM »
i'm trying to buy or build one to accomadete 8in of h2o with a 8ft head in the northeast where it freezes so i will build a power house
« Last Edit: January 16, 2006, 12:15:25 PM by hap »
wildbill hickup
« Reply #3 on: January 17, 2006, 06:17:58 AM »
Hey Hap,
Where in the Northeast are ya?????
« Last Edit: January 17, 2006, 06:17:58 AM by wildbill hickup »
hap
« Reply #4 on: January 17, 2006, 11:49:48 AM »
central New York state
« Last Edit: January 17, 2006, 11:49:48 AM by hap »
Nando
« Reply #5 on: January 17, 2006, 02:34:12 PM »
Why don't you furnish the data for the site, like head, water volume etc.
Nando
« Last Edit: January 17, 2006, 02:34:12 PM by Nando »
hap
« Reply #6 on: January 17, 2006, 02:55:35 PM »
sorry I left that info out I'm new at this.  9ft head, all the water that will pass thru an 8in. pvc pipe 160 ft long  thanks hap
« Last Edit: January 17, 2006, 02:55:35 PM by hap »
Nando
« Reply #7 on: January 19, 2006, 01:37:48 PM »
still not enough data.
What is the volume of water or the water source can supply all the necessary liters/second to obtain maximum power with the 8 inch pipe ?.
Nando
« Last Edit: January 19, 2006, 01:37:48 PM by Nando »
oregoncreek
« Reply #8 on: February 05, 2006, 01:20:15 AM »
I to am thinking of building something like the blade situation in a powerpal or the
naide system use a blade that alot like a round pice of metal cut into a pie shape,
then twist the ends. The blades on a power pal pipe a 20-30 degree angle.
they also use a .. shoot .. that spins the water around like tornado before goining
past the blades. most of those use 2-10 head.
I wonder how much difference this makes in effecnancy?
I thought of the heat pump fan also. my down draft pipe could be 12".
I thought of a low head banki, but they spin only 200 rpm , where even the low head power pal has no gearing somit must spin rather fast (no gearing propblems as in the banki).
Does any one have Good photos of the powerpal or naide?
My creek goes thru huge level changes and a banki would have to float where a down draft tube would be fine.
« Last Edit: February 05, 2006, 01:20:15 AM by oregoncreek »
