Hello Lowhead,
I like to keep things simple.
Hang the pipe on the dam, 10 feet the pipe should be able to support itself.
Main Pipe can be several smaller dia pipe to keep it cheap. More head losses... balance cost to benefit.
I assume your using a Banki turbine? (Looking at your other post I don't think it is.)
The nozzle should be a sliding nozzle to handle the varying flow rate.
Make this nozzle able to close all the way. You now have your valve.
To fill the pipe use a bilge pump and fill it up. Not a vacuum pump.
No need to get a vacuum pump. Add a second much smaller Siphon to suck from the top of the main pipes. This second Siphon will keep a lower pressure up there. It must discharge below the turbine to make sure it is a lower pressure, I do not know how much air is in the water, 1/2 to 2" pipe may be needed. Size it correctly, don't need to waste any more water than you have to. This secondary Siphon needs to have enough flow it operates with the air in it, if too small the accumulated air could stop it from working. You might even find you can close this secondary Siphon, let flow once a week or as needed. The secondary Siphon is started the same as the main.
Startup
Using several smaller main pipes can benefit by starting one, use the suction to startup the others. A Siphon will work as long as the down stream water weights more than the up stream. With 10:1 you should be able to operate with LOTS of air (for start up) If the flow is fast enough air will not be able to accumulate at the top bend. Normal operations this will not work, expect turbine to restrict flow such that air could accumulate at the top bend...
With some thinking, one small siphon can be started, use it to fill the main pipes. How the turbine is connected will dictate if this could work.
Voltage
For a given wire gage and length results in power loss, use whatever you can afford. Thinner wire is possible with higher voltages. Balance the various cost to determine what works for you!
Freezing
Flowing water does not freeze, with that said very cold weather can chill the pipe and freeze it from the boundary layer on the outside of the pipe inward, restricting flow so it no longer flows (should not burst the pipes). The water in the stream must be above 32'F, with a good flow and 10 feet of pipe, I would be surprised it could freeze. Use 1 inch layer of insulation if your worried about it. In the winter if the water stops flowing, make sure you empty the pipes of water. (Or the pipes will burst!-)
Have fun,
Scott.
