I assume you want to use it as a self excited induction generator.
Single phase units don't work too well, it might go but don't get your hopes too high.
Normally even for single phase they use 3 phase units with the load across one phase and a pair of capacitors.
You may be able to add a bit of capacitance to the start winding and put the rest across the run winding.
You could of course add magnets to the rotor and make it a synchronous generator but even then the single phase is against you.
