Author Topic: Where to buy...DC lighting fixtures?  (Read 3900 times)
yoharv
« on: November 30, 2007, 03:50:52 PM »
Hello All:  Just wondering if anyone has a good resource to buy some DC lighting fixtures?  Like a fluorescent 20W fixtures or some LED fixtures (12V)... Thanks in advance.
« Last Edit: November 30, 2007, 03:50:52 PM by (unknown) »
Re: Where to buy...DC lighting fixtures?
« Reply #1 on: November 30, 2007, 11:11:52 AM »
Well, my answer doesn't really help you I think...  B^>
Our town has a small lighting specialist shop, and it at least has basic fittings...
But I'd also think that mail-order electronics companies would do them, eg in the UK Maplin and RS Components.
« Last Edit: November 30, 2007, 11:11:52 AM by DamonHD »
Jon Miller
    • Otherpower UK
« Reply #2 on: November 30, 2007, 12:46:24 PM »
Hi yoharv,
If your after LED lights have a look on ebay, i have got one similar to this for my van:
http://cgi.ebay.co.uk/MULTI-FUNCTION-PROTABLE-60-WIDE-CAMPING-LED-LIGHT-TORCH_W0QQitemZ160185192579Q
QihZ006QQcategoryZ117110QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Its not 12 volt, but 6 volt.  Running it off a 12 volt to 6 volt adapter picked up for £2, $4 well worth it, lots of light.
« Last Edit: November 30, 2007, 12:46:24 PM by Jon Miller »
« Reply #3 on: November 30, 2007, 12:52:12 PM »
I have found good selections of 12 vdc lighting in stores that sell recreational vehicles like Motor Homes and Campers. Also have found some good stuff at Boat Stores. and here in the USA the Home Improvement stores have some cute little 12vdc flourescent fixtures that put out some pretty good light.
http://www.fieldlines.com/story/2007/6/28/16314/5486
« Last Edit: November 30, 2007, 12:52:12 PM by wooferhound »
yoharv
« Reply #4 on: November 30, 2007, 06:12:15 PM »
Great thanks:
ebay -
(fixture) http://cgi.ebay.com/s7700-Black-MR16-home-light-fixture-leds-track-lights_W0QQitemZ4400600928QQihZ01
9QQcategoryZ20706QQcmdZViewItem
(bulb)
http://cgi.ebay.com/MR16-48-LED-White-home-light-bulbs-leds-12-volt-Track_W0QQitemZ290085018659QQihZ
019QQcategoryZ20706QQcmdZViewItem
Do I need an inverter if I am running right from my 12VDC deep cycles?
Thanks again!
« Last Edit: November 30, 2007, 06:12:15 PM by yoharv »
wdyasq
« Reply #5 on: November 30, 2007, 07:14:42 PM »
http://store.solar-electric.com/thinlites.html
I found that site has lot of fixtures. I want to purchase a particular T5 fixture for water treatment.
Lowes had some 12" T5 8 Watt units for ~$10 that run directly on 12V or 8 AA penlight batteries,"Amertac 73040L Flourescent"
« Last Edit: November 30, 2007, 07:14:42 PM by wdyasq »
coldspot
« Reply #6 on: November 30, 2007, 07:48:16 PM »
Jon M-
You could just hook two together and use the 12 volts without the loss you get going to 6 volts.
(Pos to Pos on first then from its neg to Pos on #2 then its Neg to Neg)
my
$0.02
« Last Edit: November 30, 2007, 07:48:16 PM by coldspot »
$0.02
Capt Slog
« Reply #7 on: December 03, 2007, 02:29:26 AM »
REUK sells 12v LED reflector bulbs, they are around £3.50 each.  These are the mr16 type.  They are a bit narrow angle, but very bright.
If you need the fittings for these,  screwfix.com is a good place to look.
Also, ALDI were selling 5 MR16 12v adjustable downlights in a pack for £10 the other week.  I managed to pick up the last pack at my local shop.
If you're not in the UK as I thought you were, all this is no use.
« Last Edit: December 03, 2007, 02:29:26 AM by Capt Slog »
pals145
« Reply #8 on: February 12, 2008, 08:58:37 AM »
**These are some of the problems I have solve after spending sooo much money and   watts on many, many other worthless light bulbs.
    ----->HOPE THIS HELPS TO ALL IN NEED AND WITH SAME PROBLEMS I ENCOUNTERED<-----.
a. (12v/wide/white/48leds
-->These are my workhorse at home pretty good one 2 or 3 watts and equivalent to     35watts  incandecent. nice, wide light and bright..
     http://cgi.ebay.com/6-x-48-LEDs-MR16-White-Light-Bulb-Lamp-WIDE-ANGLE-12V-       a_W0QQitemZ290205795906QQihZ019QQcategoryZ20706QQtcZphotoQQcmdZViewItem
b.) 12v 15watts=60 watts I bought = pretty good ones, very bright light
    -->also use these at home , very , very bright
          http://www.nolico.com/saveenergy/12_volt_marine_cfl.htm
c.) Other site with a very important info I found for those I have read with         dump load resistor problems and also problems with their wind generator controller dump problems, 1000 and 2000 watts wind turbines.
 http://store.altenergystore.com/Enclosures-Electrical-and-Safety/Miscellaneous-Electrical-Parts/Dump
-Loads-Dump-Load-Controllers/Diversion-LoadsDump-Loads/1000-W-Dump-Load-ResistorAdj-75-Ohm/p685/
I honestly hope this will help to some, and if you find anything better please let me know.
your friend
pals145@yahoo.com
« Last Edit: February 12, 2008, 08:58:37 AM by pals145 »
Electron Skipper
« Reply #9 on: March 08, 2008, 09:58:03 PM »
Forget Ebay if you are serious about modern lighting technology.
Some questions ahead of time- how deep are your pockets, and how much sticker shock can you handle?  How handy with a soldering iron are you also factors in.
Some LED panel arrays for work space lighting, comparable to that of a surgical suite can run a few thousand dollars.  But consider the 50,000 hour life expectancy too- than it is not so bad.  These are a simple screw it down plug it in and go.
Otherwise, there are arrays of various configurations available from sources like www.digikey.com  Philips has their offerings, but careful shopping and you can find cheaper comparable product.  Lite On, Lamina, and a few others have similar product lines and the pricing is close.  But the technology is out there now.
Much of what you will find on Ebay of the LED lighting technology is old and is not representative of where the technology truly is capable today.
« Last Edit: March 08, 2008, 09:58:03 PM by Electron Skipper »
busdweller
« Reply #10 on: May 29, 2008, 03:51:57 PM »
Try these guys
http://www.trulyled.com
I bought a bunch of there 120 volt/11 watt 199 LED light tubs for the bagage conpartments in my bus/home. Cheap, I think 13 bucks each. They have 12 volt stuff as well.
Peace along the way
Dennis the bus dweller N.Y.
« Last Edit: May 29, 2008, 03:51:57 PM by busdweller »
