After some search into geothermal power production . I came to Chena geothermal power . They use a carrier chiller , and turbine to make power . The heat that they need is 165 degres . What i was wondering is if you used solar power to attain the temp. of 165 to flash the r134a and could than pass through a turbine to run a 10kw or larger generator . I have enouh west facing metal roof to put solar colectors , but I am stumped as to the turbine and chiller . any thoughts on weather it would work?
Kinda wide of topical
