Author Topic: for vawt people  (Read 2733 times)
shagy
for vawt people
« on: February 10, 2007, 04:34:17 PM »
i am new at this and at some point in time i would like to build a wind turbin. I have read that a vawt will spin at a lower rpm that a hawt does. My question is , if one could take two vawts of the same size and stacked them on top of each other spinning in opposit directions, atatch the rotor to one part and the stater to the other part? would this work and if it does wouldn't it double the rpms
« Last Edit: February 10, 2007, 04:34:17 PM by (unknown) »
Re: for vawt people
« Reply #1 on: February 10, 2007, 10:02:53 AM »
Hi Shagy
 The problem is you cant spin the stator without using brushes and a commutator.Would be cool though
« Last Edit: February 10, 2007, 10:02:53 AM by vawtman »
shagy
Re: for vawt people
« Reply #2 on: February 10, 2007, 10:19:17 AM »
sorry i ment to ad that about the brushes and it also seams that the more i read the less I know
« Last Edit: February 10, 2007, 10:19:17 AM by shagy »
Re: for vawt people
« Reply #3 on: February 10, 2007, 11:10:47 AM »
I had the same idea when i first started it was a shaft within a shaft and was all exited until my dad mentioned "how would you get the power from the stator":<(oops
 Where theres a will theres a way.They would look cool.
« Last Edit: February 10, 2007, 11:10:47 AM by vawtman »
sk windpirate
Re: for vawt people
« Reply #4 on: February 10, 2007, 02:51:06 PM »
That system would work and quite well I expect. But it would that a lot of work.
why not If make a Gennerator to accomidate the lower speed VAWT? You would be building some kind alternator anyway. A 1/2hp induction motor convertion with decent magnets will reach cutin speed at about 80 To 100rpm's.
« Last Edit: February 10, 2007, 02:51:06 PM by sk windpirate »
Re: for vawt people
« Reply #5 on: February 10, 2007, 05:23:48 PM »
it might be worth an experiment or two if you can monitor the power required accurately.
the fundamental thing is there is only a certain amount of power in a given swept area.
you are dividing the swept area into two halves and running it in opposite directions so  the mags are passing the coils  at twice the speed .
but what happens when you put the Geni under load?
I'm thinking the geni might slow down twice as much .
if your willing to belt/ gear drive the alternator you can make up for the slow rotational speed
or build an alt with a larger dia.
it's an interesting idea.
why not do a working model first?
« Last Edit: February 10, 2007, 05:23:48 PM by electrondady1 »
shagy
Re: for vawt people
« Reply #6 on: February 11, 2007, 07:14:48 PM »
it was just a thought that i had. Kinda sounds like this would be more of a toy than a working turbin
« Last Edit: February 11, 2007, 07:14:48 PM by shagy »
Re: for vawt people
« Reply #7 on: February 11, 2007, 09:26:17 PM »
seems like a worth while line of exp to me shagy .
don't give up on it too fast.
if you can make it work everyone will jump on board.
« Last Edit: February 11, 2007, 09:26:17 PM by electrondady1 »
commanda
Re: vawt; counter-rotating magnet rotors
« Reply #8 on: February 12, 2007, 01:41:42 AM »
I've been holding off on this idea for quite a while. This might be an opportune time to raise it for comment.
The stator (coils) is stationary. The top magnet rotor is attached to the upper vawt thingy, and spins; lets say clockwise.
The lower magnet rotor is attached to the lower vawt thingy, and spins the other way, say counterclockwise.
So tell me why it won't work. There must be a reason, otherwise it would've been done long before now.
« Last Edit: February 12, 2007, 01:41:42 AM by commanda »
shagy
« Reply #9 on: February 12, 2007, 05:59:41 AM »
I understand how you determine the power of the swept area for a hawt but is the swept area for a vawt different. I also know that there are several differnt types of vawts does each one have a different swept area for the same size
« Last Edit: February 12, 2007, 05:59:41 AM by shagy »
« Reply #10 on: February 12, 2007, 07:01:47 AM »
Hi Commanda
 Had the same thoughts,not a good idea has i found out.
 http://www.fieldlines.com/story/2006/10/10/232638/13
« Last Edit: February 12, 2007, 07:01:47 AM by vawtman »
« Reply #11 on: February 12, 2007, 08:41:34 AM »
Heres a calculator Wind4reg posted awhile back.Fun to play with.
http://users.xplornet.com/~rmanzer/windmill/rotor_calculator.html
« Last Edit: February 12, 2007, 08:41:34 AM by vawtman »
« Reply #12 on: February 12, 2007, 10:54:03 AM »
commanda, i think we are talking about two different things here.
your proposing a stationary stator with two counter rotating mag disks.
i can see problems with with getting the poles to sync up .
what shagy is suggesting(i assume) is a conventional dual rotor but with the stator counter rotating .
the frequency would be double.
four bearings would be required as well as a set of brushes
« Last Edit: February 12, 2007, 10:54:03 AM by electrondady1 »
elvin1949
Re: for vawt people
« Reply #13 on: April 17, 2007, 10:56:32 AM »
shagy
 It is a very doable design.
A lot of hawt's use slip ring's so you can find them.
 On a vertical wind gennie you put the mag's on the bottom of the top set of blades and the stator
on the top of the bottom set of blades.
 Put your rectifers INSIDE the bottom rotor
and the slip rings at the bottom of the bottom rotor.
 I ain't very good with word's SOOoo hope
you get the idea.
Elvin
« Last Edit: April 17, 2007, 10:56:32 AM by elvin1949 »
