Author Topic: solar  (Read 827 times)
ricksure
solar
« on: February 19, 2007, 01:52:43 AM »
Can i have my 15 watt 1 amp solar panel connected to the batteries currently being used
or will it hurt my panel ? (draw to much through it). Or does the panel work like a battery and give only what it has.
« Last Edit: February 19, 2007, 01:52:43 AM by (unknown) »
icicle
Re: solar
« Reply #1 on: February 19, 2007, 12:44:22 AM »
Do not know? How can someone have 15 watts, 1 amp panel with out knowing the voltage output.
If my under standing is right 15 volts x 1 amp = 15 watts. never heard of a panel that small what brand is it
please don't quote me on this but I would think you might burn it out.
« Last Edit: February 19, 2007, 12:44:22 AM by icicle »
AbyssUnderground
Re: solar
« Reply #2 on: February 19, 2007, 02:41:34 AM »
Yes you can connect a panel to a battery currently being used, and it will not be damaged. I wouldn't recommend running anything directly from the panel due to voltage and current fluctuations.
15watt panel @ 1 amp will be a 12v nominal panel (21VOC) but don't expect 1 amp too often unless you have lots of direct sun. My 18watt panels dont even put out 1 amp at the best of times.
« Last Edit: February 19, 2007, 02:41:34 AM by AbyssUnderground »
ricksure
Re: solar
« Reply #3 on: February 19, 2007, 03:20:35 PM »
thank you for your answer. I am in Canada and Canadian tire sells this panel. Yes it is
small but I am just playing around. I am a generator tech and get used batteries from
old one`s  switched out for preventative maintenance.
« Last Edit: February 19, 2007, 03:20:35 PM by ricksure »
