Author Topic: Solar Stregnth  (Read 805 times)
cacci
Solar Stregnth
« on: April 19, 2007, 01:46:48 AM »
I have recently obtained around ten solar cells from solar lights and I am using them to make a hydrogen generator.  The generator works great but my question is if wiring the solar panels in series or in paralell will change the output of hydrogen.  Also, will voltage increase the hydrogen output?  What else can I do to make more hydrogen from the same amount of solar cells?
« Last Edit: April 19, 2007, 01:46:48 AM by (unknown) »
Re: Solar Stregnth
« Reply #1 on: April 18, 2007, 09:58:58 PM »
same number of watts either way. In series you get cell voltage times the number of cells at whatever the cells current rating. Paralell you get cell voltage at the cell current times the number of cells.
« Last Edit: April 18, 2007, 09:58:58 PM by MaryAlana »
luckeydog
    • Colorado Wind Power
Re: Solar Strength
« Reply #2 on: April 19, 2007, 05:01:49 PM »
what you are looking for is low voltage high amperage.
it only takes about 1.5 volts to split water.
there is a lot of info on this subject at http://www.hydropowercar.com
Luckeydog
« Last Edit: April 19, 2007, 05:01:49 PM by luckeydog »
cacci
Re: Solar Strength
« Reply #3 on: April 20, 2007, 08:30:12 PM »
Thanks for your help and the website!  I will use the information to help build the generator.
Cacci
« Last Edit: April 20, 2007, 08:30:12 PM by cacci »
