Author Topic: Baldor 24V DCPM 1/4 HP Geared motor  (Read 1500 times)
farhan
« on: April 23, 2008, 07:37:19 PM »
Hello,
I'm a newbie and i wanted to ask an expert or anyone who could help me. I have abaldor 24V DCPM 1/4 HP 10 AMP geared motor, can it be used as wind generator?
Thanks in advance.
« Last Edit: April 23, 2008, 07:37:19 PM by (unknown) »
Re: Baldor 24V DCPM 1/4 HP Geared motor
« Reply #1 on: April 23, 2008, 01:56:09 PM »
Not very well.  The gears kill the idea.  It might work a little, but I would say don't waste the effort and money.
If the motor's RPM is low enough, then the motor might work, but usually geared motors are way too fast.
« Last Edit: April 23, 2008, 01:56:09 PM by ghurd »
farhan
« Reply #2 on: April 24, 2008, 03:44:04 AM »
Thank you for your comment, the motors rpm after putting the gears are 178, so thats low, with just a turn from hand it makes 12v easily and lights a 12v bulb. The geared part can be removed as well but i'll have to check what rpm it needs then because after removing gears even if i twist with hands it makes very low volts.
« Last Edit: April 24, 2008, 03:44:04 AM by farhan »
feral air
« Reply #3 on: April 24, 2008, 08:22:03 AM »
I would make a vawt and attach the motor to that - it might work. Maybe a 55gal barrel (or 2) would be enough...I dunno, just a thought. take it easy
« Last Edit: April 24, 2008, 08:22:03 AM by feral air »
farhan
« Reply #4 on: April 25, 2008, 02:01:03 AM »
Thank you for your comments.
Let me make myself more clear. I have a 600W UPS and 12V 145Amp Battery installed in my home. The power goes alot here in Karachi, Pakistan. 4 hours a day is normal. My ups gives me a back up of 2 hours with 4 fans and 4 tubelights running. what i want to do is somehow charge the battery while there is no power at home. I just want the system to charge the battery and we have good winds here because i live near the sea.
The motors you all discuss are not available here, even if they are they cost alot. Car alternator everyone says is not a good option, DCPM motors are good. Any idea?
« Last Edit: April 25, 2008, 02:01:03 AM by farhan »
