Author Topic: micro wind turbine using bicycle wheel  (Read 3976 times)
CarlF
« on: June 30, 2008, 04:49:51 AM »
Just wanted to share a picture of a project that I have been working on.
Since I am in a light wind area (S Cal, rated = 0), I wanted to try my hand at developing a micro turbine that runs in a slight wind. The components are a 9 coil stator, 18 AWG, with 80 turns, star wiring,  12 neo magnets rated at 32 lbs. My output is not all that impressive at 12volts in a stiff breaze. not sure of the amps. This was a fun project but the bottom line is that solar is probably a better choice for my area.
MASSIVE PHOTO LINK
« Last Edit: June 30, 2008, 04:49:51 AM by (unknown) »
Photo Police?
« Reply #1 on: June 30, 2008, 12:32:03 AM »
Damn that's big
« Last Edit: June 30, 2008, 12:32:03 AM by ghurd »
Re: Photo Police?
« Reply #2 on: June 30, 2008, 06:32:18 AM »
« Last Edit: June 30, 2008, 06:32:18 AM by wooferhound »
fcfcfc
Re: micro wind turbine using bicycle wheel
« Reply #3 on: June 30, 2008, 11:51:43 AM »
Hi: It's hard to tell from one photo, but it looks like you could use a much bigger sweep area for a gen of that size, like double or triple the length of the blades...
« Last Edit: June 30, 2008, 11:51:43 AM by fcfcfc »
Capt Slog
« Reply #4 on: July 02, 2008, 05:35:55 AM »
Seems a bit of a waste of the work you put into the rotors and stator to be using that "blade" set.  Try some bigger (longer) blades, see what happens.
« Last Edit: July 02, 2008, 05:35:55 AM by Capt Slog »
