Author Topic: 10' generator weight  (Read 1268 times)
soyer38301
« on: September 29, 2008, 03:04:11 PM »
Unless I have missed something along the way -- if one were to build the 10' generator shown on the otherpower.com site -- what would the approximate weight be?
I have a steel tubing tv antenna tower that I would like to use. It is 40' tall and I have access to two additional 10' sections. Just want to make sure I have enough strength built in.
Thanks.
Scott
« Last Edit: September 29, 2008, 03:04:11 PM by (unknown) »
Tritium
Re: 10' generator weight
« Reply #1 on: September 29, 2008, 03:46:15 PM »
From the PDF file on the 10' otherpower turbine manual.
The minimum tower pipe size for this turbine is 2 1/2" schedule 40.
Weight of the turbine is less of an issue than wind loading of a 10 foot blade set in high winds.
Thurmond
« Last Edit: September 29, 2008, 03:46:15 PM by Tritium »
mgtd
« Reply #2 on: September 29, 2008, 06:31:01 PM »
In answer to your question, my completed 10" weighed in at 95 lbs.
« Last Edit: September 29, 2008, 06:31:01 PM by mgtd »
soyer38301
« Reply #3 on: October 01, 2008, 07:06:03 PM »
Thanks.
Scott
« Last Edit: October 01, 2008, 07:06:03 PM by soyer38301 »
