Author Topic: New Idea for Tower ?  (Read 802 times)
gblass1
« on: November 23, 2008, 06:07:54 PM »
Just wondering if anyone has tried either a comercial light pole or a wood utility pole as a tower.  Here are some links
Wood telephone/utility poles up to 55 ft
http://www.americanpoleandtimber.com/prod_poles.shtml
Steel Light Poles up to 60 ft
http://www.lightmart.com/index.asp?PageAction=VIEWCATS&Category=2336
The utility poles are designed to be free standing and hold a lot more weight than the average residential wind turbine.  The steel light poles hold rather large and I would guess heavy lamps so I would think they would also work.  They are also engineered and rated for wind load.
George
« Last Edit: November 23, 2008, 06:07:54 PM by (unknown) »
pepa
Re: New Idea for Tower ?
« Reply #1 on: November 23, 2008, 11:35:06 AM »
check out my files. pepa
« Last Edit: November 23, 2008, 11:35:06 AM by pepa »
« Reply #2 on: November 26, 2008, 12:28:56 PM »
Sure you can.  But do the math on the allowable wind loading at the top of the tower, and you will see that it will need guy wires for a windmill larger than 5-6 feet in diameter.
Buying one of those new is a pretty expensive way to get a tower, too, considering all the other work that will still remain to finish it.
« Last Edit: November 26, 2008, 12:28:56 PM by SparWeb »
